05-07-2007, 06:50 PM   #1
mediaslinky's Avatar
The Kirons are here... (image rich content)
My new Vivitar zoom arrived today. Now I get to play with both my 75-205 f3.8 and my 70-150 f3.8 and see which I want to keep. (Pardon my color balance)
You can see the 75-205 is quite a bit bigger and heavier. The 70-150 is super smooth in all operations. The 75-205 is smooth from 70-105, and then the zoom gets pretty loose through the rest of the range. It works fine, and I could live with it, but it's not as solid as the 70-150. I don't really mind the weight. The real key, is does it take good pictures...
I have not had much time to take many with the new lens, but I always snap a couple of the African Violet on the kitchen table:
The 75-205mm-
The 70-150mm-
Not very scientific. Taken on different days and in different light, from different angles.
A couple of shots of my son:
The 75-205mm-
The 70-150mm-
Again, different days, light, and angles.
In short, I'm not ready to let go of either. I like the longer range of the 75-205mm. I will see if I gravitate to it, or the lighter, smaller 70-150mm.
slinky
05-11-2007, 12:34 PM   #2
MnR
Hi,
Both seem to be fairly equal in quality. This going to be a tough choice... If they did not cost to much then keeping both is the way to go.
I do landscapes mostly, So I might chose the 105 version. But if you need the reach then you keep the 250 version.
Kirons work well with converters, As well with them stacked.
So, it is a tough choice since both look and do quite well.
Good Luck,
Rudy
angles, couple, days, f3.8, k-mount, light, pentax lens, range, slr lens
Tax the Rich graphicgr8s General Talk 297 11-23-2009 06:07 PM
Cityscape The rich are different... FHPhotographer Post Your Photos! 1 10-12-2009 09:55 PM
Any one feeling rich? mikengstrom Pentax SLR Lens Discussion 3 12-14-2008 09:27 PM
Hi Mo--from Rich in Seattle RichWich Welcomes and Introductions 1 10-02-2007 08:35 PM
Choosing between Kirons... sounds like fun to me. mediaslinky Pentax SLR Lens Discussion 6 05-04-2007 12:02 PM
All times are GMT -7. The time now is 03:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
