07-26-2009, 09:04 AM   #1
lbenac's Avatar
Lens hood
Hello,
I wanted to ask what you guys are using for lens hood on a 85mm and 100/105mm (I recently acquire a 105mm and likely a 85mm). There are "tele" metal hoods like the B&W one but I am not clear if this would vignette or not as nobody really specify if it is FF or APC.
Thanks.
Luc
07-26-2009, 09:18 AM   #2
For my Jupiter-9 85/2, I am using the "tele" version generic metal lens hood (S&W brand) from heavystar on eBay. It works fine on APS-C with no vignette. Since it works for the 85, it should be no problem with a longer focal length. The quality is very good and the prices excellent. One of the nice things is that the hood will accept a 58mm pinch-type cap. He sells them as a pair if you like. Here is a link to his eBay store:
eBay Store - Heavy2stars Photo Gear: Step Rings, Other Brand Hoods, Nikon Camera Lens Accessories
(Bought some hoods and caps from him just this last Friday...)
07-26-2009, 09:24 AM   #3
lbenac's Avatar
Hello Steve,
Have you used this hood on film i.e. full frame?
That is my concern that a hood that is not vigneting on APC will not be wide enough on film.
Cheers,
Luc
07-26-2009, 09:37 AM   #4
QuoteOriginally posted by lbenac Quote
Hello Steve,
Cheers,
Luc
I have used it on film as well and it seems to be deep enough. It is quite a bit deeper than the built-in hood on my Vivitar 135 . I will be able to tell you better in a few days after I get my latest rolls of film back. I was out in full sun shooting wakeboarding with the J-9! It is easier than it sounds since the subject is pretty much constant distance behind the boat.
Let me find a tape and I will measure it...
07-26-2009, 09:42 AM   #5
lbenac's Avatar
Thank you very much Steve. Not that the cost is that high to make it a hard decision but it would be one more thing gathering dust...
Cheers,
Luc
07-26-2009, 09:44 AM   #6
35mm deep x 58mm inside diameter...
07-26-2009, 09:52 AM   #7
ChrisPlatt's Avatar
The Pentax 85/100 clip-on plastic hood is under $10 at KEH.
It stores in reverse so is quite convenient.
Chris
07-26-2009, 10:45 AM   #8
gofour3's Avatar
If you buy an original Pentax dedicated lens hood, which I also recommend, just be careful that you get the correct sized one.
The 52mm round hood is for K series lenses: K85/1.8, K100/4 Macro & K105/2.8
The 49mm round hood is for M series lenses: M85/2.0, M100/2.8 & M100/4 Macro
Phil.
07-26-2009, 11:50 AM   #9
lbenac's Avatar
Thanks guys.
I could not find any at KEH. I might be looking for the wrong part?
Cheers,
Luc
07-26-2009, 02:24 PM   #10
gofour3's Avatar
The lens hood you are looking for is somewhat hard to find and is costly.
(The 52mm round hood is for K series lenses: K85/1.8, K100/4 Macro & K105/2.8)
When KEH does get them in they sell for $31.00 in Ex condition. There is currently one for sale in a LA online Camera store for $55.00, but that is way too much.
Just keep an eye on eBay, I recently sold one for $4.99 that was in rough shape.
Phil
07-26-2009, 02:47 PM   #11
QuoteOriginally posted by gofour3 Quote
Phil
Luc,
There is your answer in regards to size in case you are still interested in the cheap route.
07-26-2009, 02:52 PM   #12
ChrisPlatt's Avatar
Those currently listed at KEH appear to be for the -M lenses,
but it might be worth giving them a call to confirm.
Pentax manual focus lens hoods at KEH
Chris
07-26-2009, 02:56 PM   #13
Ratmagiclady's Avatar
By the time you get to an 85mm, you usually actually have to go out of your way to find a hood that will vignette on you, even on full frame. You're pretty safe with what 'Mr. Heavystars' sells in a generic metal tele hood. I use a lot of that brand, myself.
07-26-2009, 06:38 PM   #14
lbenac's Avatar
Hello everybody and thanks a lot for all the information. Indeed the cheap solution seems very attractive and I will likely give it a try. What I am thinking is that way I do not really need an UV filter for glass protection and cleanliness. The drawback is that to use a circ pol or an orange filter I need to unscrew the hood.
As anybody tried a spacer ring which has a thread at both end so that it would be possible to screw a filter at the end of the "hood" without removing it. The one I have seen on eBay are 36mm deep which is about the same as the hood.
Cheers,
Luc
07-26-2009, 08:16 PM   #15
raymeedc's Avatar
I use an Adorama collapsible rubber hood on my 85mm 1.8 M42 Takumar. I don't remember what it cost, but probably less than $10. My 105 Takumar came with it's original Pentax metal hood.
85mm, hood, k-mount, lens, pentax lens, slr lens
For Sale - Sold: Pentax Rectangular Metal Lens hood for 58mm Lens (Worldwide) oneill Sold Items 2 03-19-2010 05:12 PM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 07:18 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
