Originally posted by pierrot35 Well, even with your explanation I don't see how to remove blades in the situation below. I remove the three screws but after...
If someone has a clue because I would like to keep this good lens.
Thanks,
Pierre.
In this picture, you can see the aperture actuator lever at the top of the lens. Right next to that lever, you should be able to press on the housing with a flat screwdriver and it should pop right out.
You can see in this one how the screws are still in place:
And with the screws removed, and the aperture assembly taken out:
