07-29-2009, 03:21 PM   #1
f-stops....what do they stand for???
Sorry for my ignorance but I was just cleaning Ruby, Charlie, Fat Albert and Pop and it dawned on me that even though I know what f-stops mean in a practical sense...eg.f1.8 open aparture = faster shutter speeds and less DOF etc. versus f13 =slower shutter speeds and lots of DOF.
But then I asked myself...."1.8 what?...13 what?
What do the numbers actually mean? What are they a measurement OF?
I am annoyed that I don't actually know.
Please advise before my kids ask me.
Jack.
07-29-2009, 03:31 PM   #2
Here is more than you ever want to know:
F-number - Wikipedia, the free encyclopedia
In case you are in a hurry...in layman's terms, it is the focal length divided by the diameter of the aperture.
07-29-2009, 03:41 PM   #3
Thankyou and you were right.
Its much more than I would EVER want to know f/\# = N = \frac fD \
Cheers
07-29-2009, 04:37 PM   #4
mtroute's Avatar
QuoteOriginally posted by jackbullet Quote
Cheers
then how can some zoom lenses have a constant f# throughout it's FL without changing the diameter of the aperture?
07-29-2009, 04:42 PM   #5
QuoteOriginally posted by mtroute Quote
DOH!!!! because, F/N = F-.8xFN multiplied by factor zoom!!!! Thats why!!!
07-29-2009, 06:22 PM   #6
jimH's Avatar
Again, a very succinct explanation!
07-29-2009, 06:40 PM   #7
The actual calculation uses the "affective" aperture. My understanding is that constant aperture zooms have a mechanism that is able to modify the affective aperture at shorter focal lengths. I know that sounds like a bit of a cop-out, but that is the explanation I was given.
07-30-2009, 06:28 PM   #8
Sean Nelson's Avatar
If you remove a zoom lens from your camera and look through the front of it while holding it up against a white background and rotating the zoom ring, you'll see that the apparent diameter of the white circle decreases as you zoom toward a wider angle of view. This is the "effective aperture", and it's what's used in the f/ratio calculation.
07-30-2009, 07:00 PM   #9
Lowell Goudge's Avatar
It is a function of how the aperture blades are located within the lens and the light path.
Constant aperture zooms are more expensive to make, as a rule (especially in telephoto zooms) , because to offer the constant (and low) F number through out the whole range, usually drives the front element diameter up. At the end of the day, no matter where you put the diaphram on the lens, a 50 mm (for example) diameter front element will only ever be an F4 200mm lens (note here front element is the real front element diameter not the filter diameter).
During the mid 1980's as TTL flash became more dominant, the need for constant aperture zooms went away, TTL metering could cope with the loss of lght from zooming, and with TTL flash, the sensor saw light off the film plane directly, so the need for constant aperture zooms went away. Since variable aperture lenses were cheaper, and offered at the short end, faster lenses, they became popular. It is a case where camera technology allowed lenses to become less expensive.
dof, k-mount, pentax lens, shutter, slr lens, speeds
1/2 or 1/3 EV stops? Nanthiel Photographic Technique 24 09-03-2008 09:40 PM
the LBA stops here 247nino Pentax SLR Lens Discussion 9 05-01-2008 11:17 PM
AF and f-stops elne Pentax DSLR Discussion 1 03-18-2008 02:51 AM
nd filter, how many stops? dtra Pentax Camera and Field Accessories 2 10-23-2007 05:19 PM
All times are GMT -7. The time now is 03:27 PM. | See also: NikonForums.com, part of our network of photo forums!
