07-30-2009, 09:23 AM   #1
Rense's Avatar
Super-Tak 200mm/4: too many adjustable rings, who can help?
The scale ring on my Super-Tak 200/4 - between the aperture ring and the focus ring - is suddenly turning around, and I am not very happy with that. How can I solve this problem, anybody any idea??
07-30-2009, 09:48 AM   #2
JonPB's Avatar
On my Tak 135mm, there are three small screws in that ring. I'd look for anything resembling a screw on the moving piece and see if any are loose. Hopefully that's all it is.
07-30-2009, 09:49 AM   #3
Just1MoreDave's Avatar
The ring with the 22-11-4-diamond-4-11-22 DOF scale on it? It looks like there are grub screws on that to pinch it in place. You'll need a tiny screwdriver for slotted screws - usually something in an eyeglassrepair kit will fit. There are probably three screws, 120 apart. You may want to first loosen all the screws, slide the ring forward a bit, then use a toothbrush between that ring and the aperture ring to brush out accumulated grit. Then slide the ring back in place, not pressing too hard against the aperture ring, and tighten the three screws.
07-30-2009, 09:54 AM   #4
Rense's Avatar
QuoteOriginally posted by JonPB Quote
QuoteOriginally posted by Just1MoreDave Quote
Thanks guys, that was very quickly, and very helpfull! I just overlooked the screws, they are VERY tiny Thanks again, it's in full working order again!
k-mount, pentax lens, slr lens, super-tak
For Sale - Sold: Quantaray 28mm, Super Tak 55mm f1.8, Gemini 80-200mm (Worldwide) cheekygeek Sold Items 13 04-09-2010 07:02 AM
Super-Tak f4 200mm Garyleed Pentax SLR Lens Discussion 7 12-13-2009 10:32 PM
Super Tak 200mm F4 - Lessons Igilligan Pentax SLR Lens Discussion 18 07-31-2009 11:25 AM
All times are GMT -7. The time now is 11:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
