08-13-2009, 02:57 AM   #1
Can 50-200 hood be used on 18-55?
Can the hood from the DA 50-200 be used on the DA 18-55 ?
Exact fit?
08-13-2009, 03:27 AM   #2
LeDave's Avatar
I think they can fit since they're both 52mm. But the problem is the hood on the 50-200 isn't designed for use with the 18-55, so maybe there might be some lighting problems when you use them with each other. From what I've seen, the 18-55 uses a petal hood and not a full one. Plus the 18-55 is wider than the 50-200, so maybe you might see some of the hood in the wider end because it's so big. I wouldn't try it though.
08-13-2009, 04:35 AM   #3
axl
I believeit would fit but at wider end it would cause vigneting. So efectively it would only be usable from I'd say 35mm to 55mm. But how wide could you go without the vignettinng to occur, that's just a layman's guess.
BR
Peter
08-13-2009, 08:52 AM   #4
Marc Sabatella's Avatar
Vignetting would certainly occur at some focal lengths and some apertures. Might take some trial and error to figure out where. If I were trying to save space in the bag, I'd be more inclined to go the other way - use the 18-55 hood on the 50-200. The worst that happen there is that it wouldn't be as effective as it should. Or try a collapsible rubber hood for both.
08-13-2009, 03:48 PM   #5
GerryL's Avatar
QuoteOriginally posted by johngs Quote
Exact fit?
They are an exact fit as I have both of those lenses.
They however would produce vignetting as others have already pointed out as the wide on the 18-55mm would be overshadowed by the extended lens hood of the 50-200mm.
da, hood, k-mount, pentax lens, slr lens
New FA*80-200/2,8 lens hood StigVidar Pentax SLR Lens Discussion 2 06-28-2009 02:03 PM
Bayonet lens hood for Sigma 28-200 w 72mm filter diameter? Sodbuster Pentax SLR Lens Discussion 0 03-16-2009 09:43 AM
All times are GMT -7. The time now is 07:30 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
