08-13-2009, 05:33 PM   #1
bdery's Avatar
Lens focuses fine at close distance, not sure about infinity?
Hi,
I recently acquired an FA 100-300 f4,5-f5,8. A very fine lens, with good performances.
I tested it at short focus distances and get great results, handheld. However, focusing at long distances (a few hundred meters) seems to give me average results, really hit-or-miss. I took Moon shots with a tripod and got some nice sharp images, but the best pictures were with an aperture between f16 and f18. If I manually focused the lens to infinity, focus was off, the camera set the focus point just a tad before infinity.
When taking pictures of trees at a few hundred meters (near infinity, right?) I sometimes get a sharp picture, with lots of details, but sometimes it seems impossible to get a clear shot. The lens is usually used around f9 (in daylight), handheld with SR on, and a shutter speed that's high enough considering the focal length.
I have the K20D so focus adjustments are possible. However, since focus doesn't seem to be off in every situation, I'm not sure about this. I haven't yet run a test with a focus chart, but I plan to.
I know the lens can deliver extremely sharp results with distant subjects at 300 mm, so it's not a matter of the lens performing poorly optically.
Any thoughts on the best tests/adjustments to make?
08-13-2009, 07:51 PM   #2
borno's Avatar
I don't know if it is the case, but haze and heat waves can really mess things up with a long lens trying to get a faraway shot. Just a thought.
08-14-2009, 04:25 PM   #3
I have the same experience, too. I suggest that you shoot some distant objects on a tripod and then do the AF adjust based on that.
In my case, the AF for near objects also seems to be OK after the adjustment, some 80 or 90% of the time. Good luck.
08-14-2009, 09:27 PM   #4
Damn Brit
Guest
It's possible that when you were shooting the moon, AF might have been thrown off by the slight halo effect caused by any haze. f/16 would be about right for moon shots
I think.
08-16-2009, 12:43 PM   #5
bdery's Avatar
Thanks for the feedback. I will try AF adjustments with distant subjects and see how that leaves me at close distances
distances, focus, infinity, k-mount, lens, meters, pentax lens, pictures, results, slr lens
BEST lens for fine art repro? albrechtnamatdurer Pentax SLR Lens Discussion 14 01-20-2010 07:01 AM
Tamron 18-250 close focus distance raider Pentax SLR Lens Discussion 6 09-13-2009 09:11 PM
New Sigma lens front focuses slightly... joeyc Pentax SLR Lens Discussion 7 06-26-2009 04:04 PM
Sigma 20 1.8, nails close focus, back-focuses at a distance. What to do. adhall82 Pentax SLR Lens Discussion 1 05-07-2009 11:38 PM
which Lens focuses faster? racinsince55 Pentax SLR Lens Discussion 3 01-12-2008 06:02 AM
All times are GMT -7. The time now is 07:56 PM. | See also: NikonForums.com, part of our network of photo forums!
