08-20-2009, 07:20 PM   #1
scorpioh's Avatar
Wobbly lens barrel of DA70?
Just to check with those who own this lens, does the barrel wobbles? Mine felt like it could move probably 0.5mm laterally. The rest of my DA limiteds are much tighter. Can it be tightened up? Thanks.
08-20-2009, 08:27 PM   #2
I just got one off the marketplace a few weeks ago. No wobble or play in mine at all.
08-20-2009, 08:52 PM   #3
scorpioh's Avatar
Hmm, I think all the DA limiteds wobbles to some extend. Perhaps I need to clarify that I am refering to the part which extends out as the focus ring turns. It is not tightly coupled to the lens barrel.
08-21-2009, 12:27 AM   #4
I have 4 DA Ltd lenses, including the 70mm, and all of them has a little wobble in the barrel. As have most lenses I have owned, including some Canon L lenses. I wouldn't worry about it.
08-21-2009, 01:03 AM   #5
creampuff's Avatar
There was a post posted by frank some while back where a DA 70mm Limited just came apart.
https://www.pentaxforums.com/forums/239077-post15.html
I've seen another DA 40mm Limited come apart too where the internal prongs came off the helical thread. Personally I'm not so impressed with the DA Limited build quality compared to the FA Limiteds.
A DA 40mm I had and which later sold also had a slight wobble. The only DA Limited I use is the DA 21mm but only because of the focal length and because I got it cheap.
08-21-2009, 01:11 AM   #6
gazonk's Avatar
QuoteOriginally posted by scorpioh Quote
Mine has almost no wobble at all. Feels extremely tight compared to my DA16-45, which really is a wobbly lens fully extended (Speaking of wobbliness and feel of build quality, I tried the 18-55 WR the other day, and that really feels like a much more expensive lens than it is).
08-21-2009, 01:33 AM   #7
scorpioh's Avatar
QuoteOriginally posted by creampuff Quote
I agree. The FA limiteds are built to an impeccable tolerance, perhaps less the FA43, where the barrel is concern. The slight complain is the aperture ring which seems a bit loose but that is just nick-picking.
08-21-2009, 06:37 PM   #8
My copy of DA-70 has slight lateral play as well, when the lens is extended out. It's not much, but seems like a lot given the size of the lens. I'd be more worried if it wobbled vertically. I don't remember noticing this with my DA40. I'll have to check again.
I also never understood why everyone raves about the build quality of the DA limited series. Apart from the mount, everything feels a bit light, thin and brittle. While the DA40 seems solid (mostly due to its compactness), I don't think any are comparable to FA series and unlikely to outlast any FA lens.
08-21-2009, 07:12 PM   #9
scorpioh's Avatar
QuoteOriginally posted by wasim_altaf Quote
Same sentiments here. The DA limiteds are very well-built in comparison with the mass-market plasticky modern lenses. But really, they are still a notch lower compared to the FA limiteds.
09-04-2009, 07:52 PM   #10
MikeW's Avatar
I just received a DA 70 today. I am very, very impressed with it. I noticed no wobble in the barrel at all. It looks very well made to me. It reminds me of my old Leica screwmount lenses.
09-26-2020, 11:31 AM   #11
My DA 70 has just come apart! I can't get the two parts together again. Looks like I will need to disassemble it first?
They don't make them like they used to.
GR  Photo
GR  Photo
GR  Photo
04-26-2021, 07:01 AM   #12
gazonk's Avatar
QuoteOriginally posted by davidatbeat Quote
Going through my subscribed threads, I saw this and remember I intended to reply to this when you posted it. This actually happened to me, too, some 11 or 12 years ago. I bought the lens in Japan and only had 1 year international guarantee which had expired, but the price of the repair was reasonable. Did you get yours fixed?
04-27-2021, 08:30 AM   #13
Thanks for reply. I did not get it fixed. It was almost possible to put the parts together after some disassembly, but not completely possible. To get the required access I would need to remove the rear base plate from the lens, but I was not able to turn some of the small screws holding it. I was afraid of destroying the screw heads. It might be possible with the correct Japanese spec screwdriver. I gave up.
Last week I bought a second-hand FA 77mm. I hope it is a better construction.
I think it is very important to be very careful when removing these lenses from camera body, as I think that twisting the lens when doing this is what causes the two halves to come apart.
Edit: Beautiful photos in the Gallery, by the way!
04-28-2021, 12:46 AM   #14
gazonk's Avatar
If I remember correctly, the repair guy said that this isn't a construction problem, some of these lenses were simply poorly assembled in the factory. The lens has been working flawlessly ever since I got it repaired (except for a slight front focusing problem, which I need to finally calibrate for my K-1 as I did for the K-5!). The repair costs were very moderate for one of the world's most expensive countries.
Thanks! I've almost forgotten about that, I see that my last gallery upload was 5 years ago.
04-28-2021, 08:22 AM   #15
I wonder if some of the issue, at least for used copies floating around, is the number of owners who practically tear the lens apart trying to get the hood off.
barrel, k-mount, lens, lens barrel, pentax lens, slr lens
Pentax DA* 16-50 lens barrel movement(?) Egg Salad Pentax SLR Lens Discussion 8 02-05-2010 06:48 AM
smc-a 35-70mm f4 lens a little wobbly.. VTPentax Pentax SLR Lens Discussion 1 10-28-2009 07:16 PM
Paint the lens barrel vanchaz2002 Pentax SLR Lens Discussion 2 07-09-2008 01:24 AM
Does DA70 barrel wobble? selar Pentax SLR Lens Discussion 2 03-12-2008 05:40 AM
Loose lens barrel figmental1978 Pentax SLR Lens Discussion 1 10-07-2007 05:15 PM
All times are GMT -7. The time now is 01:11 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
