1) As I understand it, the extra pin only causes problems on auto focus bodies so the ME Super should be fine.
2) You should get a macro lens. You'll probably find that you can't get close enough with the regular 50mm lenses.
3) You can mount pretty much any Pentax K-mount lens on the ME Super, but they won't necessarily work well. For example, the DA and FAJ series don't have aperture rings so your ME Super can't control the aperture. The -M and -K lenses are perfect for your ME Super. The -A, -F, -FA lenses will work great also, but they have extra features that your camera doesn't support and are generally a bit more expensive.
4) I haven't used the Rikenon 50mm myself, but from what I've read, it seems to be comparable to the Pentax-M 50mm f/2. It sounds like a good lens.
