08-22-2009, 11:06 AM   #1
Question on 18-25mm Comparative Sharpness On ?????
Going to William S. Hart Ranch tomorrow to take a few shots ..... packing light.
At 18-25mm which is the sharper lens, the 18-55mm AL II or the 18-250mm Pentax. If the 18-55mm is better I'll pack the 55-300mm as my alternative long lens. If the 18-250mm is sharper, I'll pack a 15mm Limited.
Thank you in advance.
wll
08-22-2009, 11:10 AM   #2
WMBP's Avatar
QuoteOriginally posted by wll Quote
I have never used the newer kit (18-55) lens. It's supposed to be pretty good but I can't compare it's image quality within its limited range with that of the Pentax 18-250 (which I do own).
I will say that I think the 18-250 is quite good, especially in good light. If I were you, I'd pack the 18-250 and the 15, no question about it.
Will
08-22-2009, 12:03 PM   #3
philbaum's Avatar
wll
Don't have the kit lens but have spent a lot of time with the 18-250. The latter zoom has barrel distortion at 18mm end but seems quite sharp there. Don't think you'll see the barrel distortion outdoors except for architectural features. Then from 18 to 135mm, mine is quite sharp. I'd definitely take the 18-250 because for ranch work, i just wouldn't cut off my photos at the 25mm lens, perhaps thats just me :-)
08-22-2009, 12:21 PM   #4
wll
QuoteOriginally posted by philbaum Quote
Phil,
Would not cut photos off there, just using that as a reference point as I like wide stuff. Being that this a ranch setting and they have Buffalo there, I'll be using the 135-250mm end quite a bit.
I may just take me Tamron 1.4 extender for giggles.
wll
18-55mm, k-mount, lens, pack, pentax lens, slr lens
Sharpness VS Fine-Sharpness in k20d wasim_altaf Pentax DSLR Discussion 8 10-12-2009 11:41 AM
General Lens sharpness Question-NOOB kenhreed Troubleshooting and Beginner Help 1 08-17-2009 09:25 AM
Nice chart showing comparative lens sizes jsherman999 Pentax SLR Lens Discussion 1 04-21-2009 12:25 PM
Fine sharpness and sharpness move together on K20D 1.01 morfic Pentax DSLR Discussion 2 07-11-2008 09:18 PM
A sharpness question... Igilligan Post Your Photos! 5 02-17-2008 10:56 PM
All times are GMT -7. The time now is 09:25 AM. | See also: NikonForums.com, part of our network of photo forums!
