08-23-2009, 11:07 AM   #1
Double Lens Cap
I just bought a dozen rear lens caps from FleaBay - cheap, about $1.10 each.
I use them to make double lens caps. Using Gorilla tape, I attach 2 lens caps back to back.
The double lens cap will make lens changing in a field a lot speedier and safer: With the double lens cap already attached to the new lens, I detach the old lens from the camera body, then attach the old lens to the available side of double lens cap, then detach the new lens from the cap and attach the new lens to the body. I don't feel the need for 3 paws and this significantly reduces the chance of dropping a lens.
Try it, it's likely that you'll like it. There's nothing to lose.
Make sure that you always hold on to the lenses. Think of this as a way to keep the cap attached to the lenses, not the lenses attached to the cap.
08-23-2009, 12:32 PM   #2
TKH
TKH's Avatar
Nice work, but I saw this at friend tzcobrettis Bag as lens caps glue together with a strong patex so you need no (and see no) tape.
Best,
Rainer
08-23-2009, 01:08 PM   #3
Fixcinater's Avatar
I like this idea very much. Not much more room taken up in the bag, safer, and probably cleaner.
An added bonus is that you'd be able to keep your original caps safely at home for better resale down the line, if you're one to worry about such things.
08-23-2009, 04:06 PM   #4
GerryL's Avatar
I actually have been contemplating on buying these caps on ebay but am a bit reserved..not about the function though but more about the price and the quality of the product.
I have actually thought about something similar before but found out that they where already marketing the stuff.
Nice job on the tape though..brilliant alternative.
08-23-2009, 06:43 PM   #5
QuoteOriginally posted by GerryL Quote
Yeah, I know double lens caps are commercially available.
Op/Tech makes them. I'm sure they're good. But I'm just too cheap....
It's $19 a copy
...a bit reserved..not about the function though but more about the price and the quality of the product.
Price: It's $5.88 + $2 for 5 caps. 10 caps for $5.88 X 2 + $3 shipping.
Quality: Not as good as Pentax (the one with large base to cover the electrical contact), but not far behind. After all, what can go wrong with lens caps?
body, cap, caps, k-mount, lens, lenses, pentax lens, slr lens
Lost lens cap on 18-55mm DA L. Can anyone confirm if this eBay cap is the correct one philthy Pentax SLR Lens Discussion 3 10-15-2009 01:26 AM
All times are GMT -7. The time now is 09:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
