08-25-2009, 10:25 AM   #1
opiedog's Avatar
AF and wide angle lenses
i've noticed from all my pentax bodies DL, K10, K2000 that using the AF with a wide angle lens is a lot of times a hit-or-miss proposition.
not to blame the lens or the camera, but wide angle lenses do pose some challenges to the camera's AF specially at farther distances.
i read this article and it sort of makes sense,
Mastering Wide-Angle
would you masters of the wide-angle lens share your AF technique ?
of course MF is an option, but i'd like to hear how you coax your AF to do it right, at least for most of the times.
tnx
jordan
08-25-2009, 10:33 AM   #2
Ash
Community Manager
Ash's Avatar
The tips on that article are quite spot-on.
I'm hardly experienced enough to have a fail-safe technique, although I have noticed at times AF locking in at around 2-3m when I wanted it to focus on something at infinity - in those cases, I can usually see in the viewfinder that the image is not completely in focus, so I just retry AF and it usually locks on properly then.
08-25-2009, 11:51 AM   #3
opiedog's Avatar
Yep. i notice that my camera's AF also locks in at objects within 1-2 meter and fails to re-focus on objects at further distances. sometimes i forget cause i'm in a hurry to take the shot, and of course, result is a blurred image.
guess this is a limit to the camera's AF mechanism.
i'm also not sure how accurate is the distance markings on the lens. i think i would just disregard what the markings indicate and go for the visual confirmation on the focusing screen.
08-25-2009, 12:13 PM   #4
I rarely let the camera choose the focus point; instead, I'm normally using either center or specifying the focus point with the buttons.
If you have something not in focus, it generally ends up being user error at that point...
08-25-2009, 12:31 PM   #5
Ash
Community Manager
Ash's Avatar
Just be proactive with the focusing, either quick shift or refocus, to get the right result.
08-25-2009, 12:59 PM   #6
opiedog's Avatar
QuoteOriginally posted by legacyb4 Quote
i always use center point only. but sometimes with wide angle lenses, the camera refuses to refocus after pointing the cam to a different object at a different distance. i put my hand in front to throw the focus off and force it to re-focus.
that article that i linked to explains it best.
af, angle, k-mount, lens, lenses, pentax lens, slr lens, times, wide-angle
Testing Wide Angle Lenses mtngal Pentax SLR Lens Discussion 7 03-06-2014 02:19 AM
Why no CHEAP wide angle lenses? bigjonnee Pentax SLR Lens Discussion 29 02-21-2010 10:12 AM
Pentax extreme wide angle lenses-where are they? lesmore49 Pentax SLR Lens Discussion 15 10-14-2009 03:27 AM
Cheap Wide Angle Lenses chrislondon Pentax SLR Lens Discussion 17 02-07-2008 06:38 PM
Does Pentax has old wide angle lenses? mulder Pentax SLR Lens Discussion 3 08-07-2007 04:03 AM
All times are GMT -7. The time now is 09:25 PM. | See also: NikonForums.com, part of our network of photo forums!
