Here are the promised (quick and dirty) beauty shots of the new lens. These were taken in a brief spare moment before setting up "The Tree," using on board flash and the FA35/2 that is my normal lens on my K10D.
This is a well-used lens, not to say that it is abused, and I think suitable for my first foray into long glass. The aperture ring clicks nicely and firmly stays in position. The focus ring is smooth and well damped, if just a
bit dry and stiff, just like my A35~105/3.5. As I understand is common with these lenses, the moving part of the barrel has a bit of lateral play. I don't know if this will affect images, but the upper portion of the image appears OOF [EDIT: It is not determined whether the image is even distorted - User Focusing Error and Camera Shake are readily apparent!].
The mount and rear section have been described extensively earlier in this thread, having been transferred to this lens by the Forum buyer of DWB's 1000/8. For the price (about half what these lenses normally sell for on auction sites) I am quite pleased with the condition.
My tripod with pan/tilt head is really more suited to a larger video camera, but has been sufficient for my use up to now. I will need to get some kind of gimball head (drat) for more stability and because the tripod ring adjustment knob interferes with the plate release levers. As you can see, the pan levers are backward - I had to mount the rig backward to seat the plate in the head. That's OK for play but will quickly get old out shooting wildlife. That being said, the set up is rock-solid. I had no fear of losing the camera or the lens, so in that way this is much preferable to a ballhead.
The following images are what I was able to produce in about 30 minutes of shooting (not nearly enough practice with such a long lens) with a K10D - a total of 30 images. Generally I had trouble getting exposure correct in M mode and getting decent focus (Focus Confirmation had trouble unless focusing wide open, then stopping down to meter). I attribute this to User Error. Switching to RAW, Av and setting max ISO at 800, then 400, extending the hood, and focusing by eye rather than using the electronics I was pleased with the 2nd image, especially since I shoot left-eye and use a +2 SMC Correction Lens attachment on the viewfinder frame rather than using my glasses. #1 is straight out of the camera, in camera jpeg. #2 is straight out of the camera, RAW, extracted in PPE. #3 is PP'ed in ACDSee, for exposure, color temp, SLIGHT Unsharp Mask and resized.
This was shot through my dining room window (and storm window) - and probably not a clean window, either - across the yards behind my house. Conditions were by no means good - any lens would be challenged by the gray, overcast light and mist in the air. The chimney is three houses down from mine, approximately 100 yards away. The furnace flue topper that appears out of focus was a surprise - it is about 1 1/2 feet beyond the face of the bricks [EDIT: On closer inspection of the actual pixels, this is actually visible camera shake, not an OOF area]. Unfortunately I blew the snow highlights, but I didn't use any filter so that also is User Error. These lenses obviously require practice and experience to nail focus - and a VERY stable platform. When I ahve decent images I'll start a new thread.
Av f/22 1/10 -1.0 EV MF ISO800 WB CLoudy Sharp +2
Av f/16 0.3s ISO400 Center-weighted -1.0 EV SR Off MLU 2s delay. I believe there was still some vibration.
