02-18-2010, 08:33 AM   #196
er1kksen's Avatar
That's a good question. Normally it doesn't. For some reason yesterday while I was working with the crow, the dial was set to Tv mode (since any old mode will just turn itself into Av mode with an M lens and I wanted to work wide open) and when I had the Sears 135mm on the camera, it recorded the aperture as f2.4. The lense's maximum aperture is f2.8, so somehow it at least seems to have picked the right aperture but was off by a tiny bit. Then when I switched it for the 50mm f1.7 it turned to f1.4. I have no idea how or why it did that. A few frames later it stopped recording the aperture and went back to normal.
Though I really wish I did have the 135mm f1.4 the EXIF claims I did.
02-18-2010, 01:26 PM   #197
QuoteOriginally posted by er1kksen Quote
...I'm wondering if there's a way I can modify this lens to constantly stop down to the aperture set on the lens, thereby allowing stop-down metering in Av mode like I had with my old screwmount.
You can saw off the actuator lever. That is a mean thing to do to a perfectly good M 50/1.7.
My advice is to work with the lens for awhile. Having the diaphragm wide open for focus without having to fiddle is a real advantage. In practice, you should only need to meter the subject once. You can then compose/focus/shoot as much as you need until either the subject or the lighting changes.
(Re-discovered this after spending some time with a hand-held meter and some truly full-manual film cameras. Manual diaphragms suck if you are shooting off tripod.)
02-18-2010, 01:27 PM   #198
Did a bit more searching for other M 50mm f.17 pictures on Flickr and it looks like what I'm seeing on my side is normal then, ie for aperture info not to be recorded in EXIF data for it.
I see that the A 50mm picks that up... That plus being able to use in AV mode might put me into lens hunting mode again :-)
02-18-2010, 03:45 PM   #199
er1kksen's Avatar
I have been working with this lens and other M and screwmount glass for ever since I started into pentax. I'm well practiced, I promise. For the photoshoot that the shot above came from, I did indeed shoot most of it in manual without needing to meter. The thing is that I generally use this as my walkaround lens as well, and changing light conditions are the norm, and I end up using a range of different apertures if it's convenient.
I don't know if I'd really call it mean. I consider the M 50mm f1.7 a "lens for life" from my end, and being able to use it in stop-down Av mode would just let me love it even more. That was what I loved about my old Meyer-Optik... just depress a pin on the side and it stopped down. And it may possibly be necessary to use it (eventually) on a 5D if Pentax never brings out that affordable FF...
02-28-2010, 02:13 AM   #200
georgweb's Avatar
Summicron 50/2 1st version on K100D
03-04-2010, 08:05 AM   #201
er1kksen's Avatar
M 50mm f1.7 @ F1.7, ISO 2500, 1/50th on the K-x. Messed with the exposure quite a bit in LR3beta, then sent it through some heavy neatimage. This is getting printed up as posters for a local show on saturday night.
03-07-2010, 07:43 PM   #202
07-15-2010, 04:47 PM   #203
georgweb's Avatar
More love for the 50s .-)
Contax 50/1.7 on K100D
07-28-2010, 03:01 PM   #204
georgweb's Avatar
... and some more
Cron50 v1 on k100d
07-28-2010, 03:38 PM   #205
Piotr's Avatar
Different flavours of fifties
Pentax PENTAX K20D,Leitz 50mm f/2 Summicron-R
1/4000s f/2 at 50.0mm iso320
Pentax *ist DS ,Pentax smc P-A 50mm f/1.2
1/1000s f/1.2 at 50.0mm iso200
Pentax *ist DS ,Pentax smc P-FA 50mm f/1.4
1/250s f/4.5 at 50.0mm iso200
Pentax *ist DS ,Pentax SMC 50mm 1:1.2
1/250s f/4.0 at 50.0mm iso200
Pentax PENTAX K20D,Pentax smc P-FA 50mm f/2.8 Macro
1/200s f/4.5 at 50.0mm iso250
07-28-2010, 03:51 PM   #206
Pentaxor's Avatar
QuoteOriginally posted by Piotr Quote
that is some nasty sharpness coming from the summicron.
07-30-2010, 08:06 PM   #207
Mechan1k's Avatar
One of my son after his first haircut ... trusty old FA50 with a bit of bounce flash
08-28-2010, 02:28 PM   #208
georgweb's Avatar
QuoteOriginally posted by Mechan1k Quote
I was waiting for the red eyes but then saw the flash on the upper part of his eyes. Great shot.
Voigtländer Color Ultron 1.8/50 + FL-D filter on K100D 1/3s. ISO200 f/8?
09-03-2010, 03:07 AM   #209
Mechan1k's Avatar
georg ... thanks for the comments .... I just realised you can see the flash in the window behind ... bad error on my part ... although it has taken me this long to realise it anyway.
Nice natural light shot of the orchestra ... also nice to see a bit of motion blur as well .... just to portray a bit of movement/action
09-08-2010, 01:31 AM   #210
georgweb's Avatar
If it takes so long to really see it, it doesn't really matter imo. Other than on photo forums with meticulous viewers of out-of-focus areas :-)
That's right, I've tried to get the moment when the conductor does the big stroke downwards and some musicians start moving rapidly .-)
Talking about movement, here's a fun shot from a pitch dark scenery, only possible with the shake reduction I guess:
Contax Carl Zeiss Planar T* AE 1.4/50 @f/1.4 ISO1600 1/5sek. on K100D
50mm, brand, club, clubs, k-mount, lens, lenses, pentax lens, slr lens
SD Association vows breakthrough 300MBps SD card speeds cdurfor Pentax Camera and Field Accessories 1 09-04-2010 08:06 AM
What is "Fast" about the fast Fifties... jess Pentax SLR Lens Discussion 11 01-04-2009 05:18 PM
Not Thrifty Fifties k100d Pentax SLR Lens Discussion 18 04-12-2008 09:57 AM
All times are GMT -7. The time now is 07:44 AM. | See also: NikonForums.com, part of our network of photo forums!
