I started off in Pentax with a couple of Sigma fast zooms. Great lenses, great output, but only worked OK for what I wanted (heavy, large...another story). I recently acquired some primes which are better suited for me (at least at this time). This is what I have (or will soon have):
DA21
M50 F1.7
DA70
M135 F3.5
DA50-200
As you can see, it's a decent 'little' kit, with the emphasis being on little. That is what I want at this time. Most of my current work is done under 100mm, which is why I went with a budget tele-zoom (50-200) for 'just-in-case'.
I see two 'gaps' in my kit: something under DA21 and something between the DA21 and M50. In the next three months I will probably be adding the DA15 and DA35, but the funds don't allow right now, yet I would like something else for now. Trying to keep any additional purchases under $300 (preferably closer to $200).
Been toying with a few options...
DA16-45 (for good overall zoom, with close focus capabilities, low distortion 24mm)
DA18-55WR (for a knock around weather resistant lens)
M35 F2.0 (fills a gap and provides me with a very sharp, fast lens)
Any thoughts, suggestions, ideas? I am probably leaning towards the DA18-55WR as that is a lens I can keep regardless of whether or not I add the two other DA LTDs. The only con is the speed and the fact that it is not much wider than the DA21.
For what it is worth, the body being used is a K200D (and a KM will follow as soon as I can find a good deal - I need a back-up!).
Thank you
