Originally posted by slipchuck Hi all and thanks to posting to my questions.... It really helps in decision making.
my question is: what would be the advantages and disadvantages of buying an auto focus that isn't made especially for digital cameras?
I realize due to the lens likely being bigger then a dedicated digital lens, and the lens fits exactly for the sensor, what else would be different?
I was more referring to the newest SLR lenses from pentax.
thanks
As everything else in this world, there are two sides to everything. Here are some of them:
- Some people believe that since APS-C-sized sensor camera only uses the middle part of the film lens, you get to use the "sweet spot" of the lens. However some people argue that since sensor is different from film, light coming thru a film lens might not fall "properly" on the sensor, therefore you should use a digital lens or optimised for digital lens.
- Some people buy film lenses because they are hoping one day Pentax will come out with a FF camera. The issue there is that you will need very good optics for a FF camera (which most likely will have more MP) otherwise your lens might not have enough resolving power to produce sharp images. I believe this is what Canon 5D users have found out. Even with the K10D that's is coming out, some people are already starting to worry about if some of the older lenses will be good enough for the camera.
hmm... that's all I can remember from what I have heard. I am sure there are other points and hopefully more knowledgeable members will input some later.
cheers
Kenny
