09-10-2009, 04:58 PM   #1
sigma 150-500mm hsm lens pentax fit
Hi I've just discovered this excellent site!
Anyway I have an issue with my sigma 150-500mm lens.
About 3 weeks ago the af stopped working...i had had it around 9 months previously and everything was fine,then suddenly boom...nothing.
So i sent it to sigma uk who then sent me an email saying that they would be replacing the hypersonic motor on the lens and it would be back in a week or so...sure enough after a week it arrived complete with a delivery note which said the lens was tested with their own pentax k2000 and found to be in perfect working order...and also a note saying no repair was needed...so i tried it on my gx20...and nothingSo i called sigma who said ''well it works on our camera so it must be a fault with yours''I told them my other lenses worked fine and i only had a problem with this lens...they then suggested i download new firmware for my samsung which i did....still nothing(unsuprisingly)now they say i have to send them my camera and the lens together which means another 2 or 3 weeks without photography
does any one have any similar experiences...or even suggestions????
please help!!!
09-13-2009, 08:37 AM   #2
Canada_Rockies's Avatar
No experiences, but a suggestion - carefully clean every contact on the lens, and the contacts in the mouth of the camera mount. That usually gets my hyper finicky DA* 50-135 going again. The contacts must be ever so slightly misaligned or not quite far enough out, and require everything to be squeaky clean.
09-15-2009, 02:35 PM   #3
thanks man...i will try that
09-15-2009, 04:14 PM   #4
Are any of your other lenses HSM/SDM?
09-15-2009, 04:14 PM   #5
Ash
Community Manager
Ash's Avatar
Welcome here.
Do you have other HSM/SDM lenses that work with your GX-20? You mentioned all other lenses work, but didn't mention if any other lenses were HSM/SDM.
If so, and they work, then it is a little strange and probably needs a repair guy to have a look at the combo.
If not, then it really may be the camera's contacts/electrical circuitry that need cleaning/servicing.
Let us know how you go.
09-16-2009, 06:15 PM   #6
hi!!thanks for the welcome
yep this is the only lens that wont work with the camera...ive written to sigma as i have tried another camera and have had the same resulti will post sigmas response
09-16-2009, 06:17 PM   #7
hey!
yes...they work fine...
i have tried the lens on a k2000 and it still doesnt work...
i am awaiting a response from sigma uk and will post it when i get it.
05-22-2010, 08:45 AM   #8
Did your Sigma 150-500mm attach and lock into place like other lenses? Mine attaches but doesn't go far enough to latch securely. I'm about to return it, but thought I'd try to ask for help before I do.
05-22-2010, 12:02 PM   #9
QuoteOriginally posted by jgandert Quote
Mine attaches to the K10D and K7 bodies OK, no different from any other lens.
Test photo, 100% crop:
05-23-2010, 12:33 AM   #10
Thank you. Then the lens must be defective? I've tried again, with the same results... turns part way, but doesn't lock into place.
04-24-2011, 08:47 PM   #11
NBC
Two questions about my Sigma 150-500 Pentax mount. I bought it brand new less than a month ago. Am having problems with it not focusing well. It focuses in and out hunting for the proper focus then stops out of focus. Any one else having this problem? I am using it on the K10D. Also, what should I use to clean the contacts?
04-24-2011, 11:10 PM   #12
QuoteOriginally posted by NBC Quote
I don't have that problem, either with the K10D or the K7.
Use a pencil eraser to clean the contacts.
04-25-2011, 12:42 AM   #13
I bought an old sigma 150 - 500mm and found that it was loose on my camera after locking it in position - I've had to add thin strips of paper between the camera and lens to make sure that it is a tight fit.
There is no obvious wear on the lens mount so I assume that the problem is poor quality standards in the manufacturing tolerances of the bayonet mount on the lens.
camera, hsm lens pentax, k-mount, lens, pentax, pentax lens, sigma, slr lens, week, weeks
Misc First shots Sigma 150-500mm f/5-6.3 DG APO HSM dws1117 Post Your Photos! 2 03-21-2010 06:19 AM
For Sale - Sold: Sigma 150-500mm F5-6.3 APO DG HSM lens kevindt Sold Items 4 08-25-2009 09:08 PM
Sigma 150-500mm F5-6.3 DG APO HSM hagbardi Pentax SLR Lens Discussion 0 12-10-2008 02:04 PM
Sigma APO 150-500mm F5-6.3 DG OS HSM ivoire Pentax SLR Lens Discussion 10 07-10-2008 06:39 PM
Sigma APO 150-500mm F5-6.3 DG OS HSM MJB DIGITAL Pentax SLR Lens Discussion 24 04-10-2008 04:23 PM
All times are GMT -7. The time now is 03:17 AM. | See also: NikonForums.com, part of our network of photo forums!
