09-11-2009, 02:37 PM   #1
flockofbirds's Avatar
Mounting issue
So i have this old vivitar lens, it weights a ton.
Anyway, when I try to mount this lens on my K200, it just does not wanna go on.
I can easily mount it on my Super Program, but no dice otherwise...
here is a picture of it,
it physically does not fit onto the mount of my K200...
Anyone know why this might be? is it just this lens?
09-11-2009, 02:41 PM   #2
Try removing the black aperture arm piece. It's held on by some tiny screws. Those guards are known for interference.
The arrow shows the offending piece.
09-11-2009, 05:42 PM   #3
Ah, ok I will try and remove that, gotta find a small screwdriver first though D:
09-11-2009, 07:29 PM   #4
I remove them all the time to fit my Non-Pentax system, without any problems.
However some people claim that it may cause Internal reflections, off the shiny surfaces.
So, with that in mind you might want to keep all the parts handy, until you try the lens. If you see anything that doesn't look right, dremal that aperture arm down, then screw it back.
Being a Vivitar lens, there's a chance it's glued in place. If I remember correctly this glue wasn't all that tough to break loose, however I don't remember what i did
09-11-2009, 11:18 PM   #5
Unless they both screw and glue it in, then I dont think it is glued fortunately, just held on by two of the smallest screws i have ever seen... I might have to look for one of those eyeglass repair kits to get a screwdriver small enough.
09-12-2009, 02:13 AM   #6
MattGunn's Avatar
I got a very similar looking lens recently, Vivitar 28-200mm, and this had exactly the same problem. Fortunately (once you have found the tools) it takes about 10 minutes to remove the rear shrowd, saw off the excess material, tidy it up with a file, touchup the exposed aluminium with a black pen and put it back on again. It fits as it should now and there are no stray reflections from shiny surfaces. Compare it to one of your other lenses to see how much of the protective shroud to remove.
09-12-2009, 04:05 AM   #7
Mike Cash's Avatar
That "R" on the lens mount makes me wonder if this is one of the lenses that will cause the infamous Ricoh stuck lens problem.
09-12-2009, 05:08 AM   #8
MattGunn's Avatar
The 28-200 doesn't have the R on the mount or extra pin visible at the bottom of the lens. If you get some suitable screwdrivers I'd take the mount off as well as the shrowd and remove that extra pin just be safe. If you keep it safe you can always put it back if you decide to sell the lens. If the construction if this is similar to my 20-200mm (and it looks like it is) then turn the aperture ring to a mid position (around f/8 - this will stop the A pin popping out and dissapearing) then unscrew the 4 screws holding the mount on. The mount should lift clear and the extra pin and its spring will probably just lift out.
09-12-2009, 10:51 PM   #9
QuoteOriginally posted by Mike Cash Quote
You have scared me now, I dont like the sound of that...
09-13-2009, 04:42 PM   #10
If the pin has a flat end, it needs to be either ground down or removed.
If it is of the more modern round end, like a ball bearing. It should be just fine.
k-mount, lens, mount, pentax lens, slr lens
Vivitar MC Tele Converter 2X PK-A/R-PK issue...or no issue? WiseOx Pentax SLR Lens Discussion 5 06-11-2014 01:14 PM
Photo Mounting Question Rmpjr7 Digital Processing, Software, and Printing 17 07-12-2009 08:17 PM
K200D BG-3 poor mounting? jezza323 Pentax Camera and Field Accessories 11 06-03-2009 11:39 PM
Sigma 35-105mm mounting issue winglik Pentax SLR Lens Discussion 2 03-31-2009 10:22 AM
A printer issue, or a processing issue... FHPhotographer Digital Processing, Software, and Printing 0 10-03-2008 12:13 PM
All times are GMT -7. The time now is 04:57 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
