Originally posted by interested_observer I have the 12-24 and like it very much. It is on my camera quite a bit of the time. I have also seen some pretty amazing images from the Sigma. There are 2 main differences 1) co$t and 2) 2.5 degrees in field of view. They are both about the same size and weight.
The 12-24 is 100 degrees wide with the 10-20 being 102.5. To me the additional 2.5 degrees, at this width did not matter that much.
I almost purchased the 10-20, but held off and spent the additional funds. The images I saw from the Sigma were wonderful and had great colors. However, I just liked the Pentax colors a touch better and waited - saving more to get the 12-24.
I have the K100 and the K20, so all of my lenses are screw drive and not SDM or HSM, so that they can move from body to body.
... hope that helps...
I will chime in since I too was in similar situation about a year ago deciding on whether I should get a Sigma 10-20mm vs the pentax 12-24mm. My decision is based on this: out of the those two ranges, how often do I use 10mm and how often do I use 24mm. I felt that 24mm is my heavily used end unless I am in a tight situation where I cannot move back. The wider end would also give more distortion. Although since my K10D is an APS-C with crop factor, it is really not that wide for 12mm.
Another thing to consider is the constant F4 which I find to be more useful; the Pentax 12-24mm is really sharp at f4 as testified by other posters on this board. So, to me, the extra few bucks for Pentax is worth it. I don't know if this DA lens will be good for FF (when Pentax have a FF body), it will be icing on the cake.
Anyway, either one you choose, Sigma or Pentax, you can't go wrong - you choice will depend on your shooting style and type of photography.
