Hello,
Years ago, a distant relative gave me this lens that happened to be Pentax K-mount. I remember using it once in my K1000. Recently, I re-discovered it. It was dirty, missing some screws and had fungus inside. Didn't look very good at all. So I decided to try and "fix" it. I've done that with other cheap lenses before and been a freebee, I was not risking much.
Found some spare minutes today under a massive thunderstorm and took apart the lens. I was able to disassemble it completely including all 3 glass elements, without molesting the delicate aperture mechanism. The elements had fungus, dust, dirt etc. Cleaned it up, put it back together and tested it. The aperture was not working so took it apart again, this time more carefully took apart some of the aperture mechanism, noticing how it works and figuring how it should work. At the end, the aperture ring is a bit flimsy but it works! I tried it several times on an empty film body before attempting the DSLR. I finally did and here you can see some rather boring quick indoors test results. I guess that outdoors in sunny bright light, it should work fine. So now I have a 135mm (202 eq in DSLR) free lens. Not that it will be used a lot but cool nonetheless.
Here is how it looks now. Unfortunately I didn't take any pics while disassembled. I was too concentrated on it trying not to mess it up.
Quick tests:
100% crop, untouched
Not too bad for a freebee!
If anything, I got from this exercise more than a free cheap lens. I got knowledge and experience!
I'm building up courage to attemp the same to my Pentax A50 f2
Thanks,
