09-27-2009, 11:16 AM   #31
Because the adjustment is routinely available during raw conversion, and CA is only one of many qualities that a lens should be chosen for.
After that, you can decide if the lens' native contrast, sharpness, bokeh or whatever else works for you.
Or, just go out and take some pictures and forget about pointless exercises.
You still didn't answer the question. Contrast is adjusted in RAW just as easily as CA. So why shouldn't we increase/decrease contrast and then decide if the lens' native amount of CA, sharpness and bokeh work for us? It seems like you think CA should somehow not be considered when comparing lenses....but for some ppl CA is very important.
Kind regards
.lars
09-27-2009, 11:20 AM   #32
Asahiflex's Avatar
Maybe the A* 85/1.4 is not so bad after all... Most of these are stopped down *a little*, only one is wide open:
1.
2.
3.
4.
5.
6.
7.
09-27-2009, 12:32 PM   #33
Wheatfield's Avatar
QuoteOriginally posted by Recercare Quote
Kind regards
.lars
I actually did answer the question, but let me go into a bit more depth for you.
As you mentioned, pretty much everything is adjustable during raw conversion.
Contrast can be adjusted on a macro level, but not really well on a micro level.
This is why I tend to leave native contrast in the mix when I look at what lenses are doing for me.
We can adjust sharpness with many tools, but all of them are a trade-off towards lessening fine detail.
Consequently, I look at native sharpness as being something that is important to compare.
Also, adjusting sharpness and to a lesser extent, contrast can really bugger up bokeh, so again, native sharpness/contrast is quite important.
CA can be adjusted or fixed in raw conversion without having any (or very little, anyway) effect on other imaging properties, and frankly, a well calibrated raw converter will remove CA as a matter of course from a lens that has it, in the same way that a badly adjusted converter can introduce what appears to be CA in a lens that is, in fact, free from it.
With this in mind, it is just as easy to say that if a lens is showing CA, it is as much a raw conversion issue as it is a lens problem.
For me, CA is only important if I can't remove it during conversion. I can't see how it would be very important to anyone, unless they had something else on their agenda
09-27-2009, 01:00 PM   #34
I agree with you regarding sharpness, but I have never had any problems boosting contrast. However, my disappointment with the A* 85 was not really related to CA. To me it didn't excel in sharpness or rendering in general, but maybe I expected too much. I tested this lens myself for 1 month and even though it's a fine lens I don't understand why it's so hyped up.
Kind regards
.lars
09-27-2009, 01:43 PM   #35
Ben_Edict's Avatar
QuoteOriginally posted by Roland303 Quote
Finally the M 85 f/2.0 surprised me with how well it does and competes very well with the best.
That is interesting indeed. SOmehow the old M 85/2 acquired a poor reputation. I don't know why. I use it rarely, but when I use it, it holds up nicely. The real advantage of that lens is its diminutive size, compared to my FA 85/1.4, which makes it a perfect choice for travelling, walking or street photography.
Ben
09-27-2009, 03:01 PM   #36
Wheatfield's Avatar
Kind regards
.lars
The A*85/1.4 is one of my favourite lenses. I've found it to be extremely sharp and with very pleasing rendering.
Of course by f/8 the M85/2 isn't really all that far behind, and the 77 is pretty much as good as the A*85 once stopped down a bit.
QuoteOriginally posted by Ben_Edict Quote
Ben
+1 on the M85/2. It's a lens that I never thought got the respect it deserved. It is a fine performer
09-27-2009, 04:16 PM   #37
treebeard's Avatar
I need to get a 77 Limited.
09-27-2009, 09:02 PM   #38
jsherman999's Avatar
M 85 oh yeah baby
Finally, the little M 85 f/2 getting some much-deserved props!
My Favorite Lens?
09-28-2009, 08:11 AM   #39
QuoteOriginally posted by creampuff Quote
This test illustrates well why I don't buy or use old lenses... very poor contrast. Old lens coatings simply cannot make it, whatever the reputation of the lens.
I am rather confident I could list a few portraits here with modern and old glass and you would not be able to pick which is taken using the old ones.
09-28-2009, 03:16 PM   #40
Thanks for this comparision! It's good to see that my dear Pancolar up there with the best lenses.
09-29-2009, 02:19 AM   #41
Douglas_of_Sweden's Avatar
Very interresting thread. Eagerly awaiting the continuation...
09-29-2009, 04:15 AM   #42
Class A's Avatar
Independently of reputation and price, the A* 85/1.4 is easily the winner in this comparison, AFAIC. Great sharpness and beautiful bokeh. At this size there is no CA that bothers me at all. And as Wheatfield says, it is one lens problem that nowadays can easily be fixed without impacting on other image properties.
09-29-2009, 04:29 AM   #43
Asahiflex's Avatar
QuoteOriginally posted by Douglas_of_Sweden Quote
Believe me, I'm very busy with this, but also waiting for the arrival of the 83mm f/1.9 Asahi-Kogaku Takumar. It has 7 elements in 4 groups, so actually it has more elements than all of the later short-telephoto Takumars. Would be interesting to see how it performs!
09-29-2009, 06:18 AM   #44
Fixcinater's Avatar
This is pretty sweet. Thanks for putting in the work and posting it up. Neat to see how the old glass stacks up against the computer-designed modern variations on the same theme.
09-29-2009, 10:24 AM   #45
rparmar's Avatar
You must be seeing something I can't see. Sharpness and contrast are both less than other lenses. Bokeh is the same or marginally better. Best I've seen for that is Voigtlander of 200mm macro.
k-mount, pentax lens, portrait, slr lens, subject, test
People Portrait Exercise Jun 19 danielchtong Post Your Photos! 1 06-27-2010 06:58 AM
For Sale - Sold: EX+++ Canon EF USM 100mm f/2.0 Fast Portrait Lens, Worldwide Shipping wallyb Sold Items 1 12-01-2009 11:23 AM
For Sale - Sold: Minolta Rokkor 85mm f/1.7 Fast Portrait Lens converted to M42 Mount wallyb Sold Items 6 02-26-2009 10:55 AM
Examples from long teles which don't include birds? Jasvox Pentax SLR Lens Discussion 49 01-29-2009 11:10 PM
Who says Pentax don't have long teles? 2 x 780mm lens coming Katsura Pentax SLR Lens Discussion 3 09-26-2007 10:38 AM
All times are GMT -7. The time now is 08:57 AM. | See also: NikonForums.com, part of our network of photo forums!
