Originally posted by Spotmatic Pentax Imaging recommended a circular. Yes, a linear will work but there is nothing to stop Pentax from altering the way they implement AF or metering in the future Also, if you are using the PL in bright sun a filter with superior coatings is the best option. I am in Florida, he is in Australia the sun in the frame/flare is a real issue so it makes no sense to use a cheap filter especially with a WA lens.
I'm merely refuting your statement that he "
needs a circular polarizer",
which is plain and simply not true.
Pentax imaging recommends circular polarizers because the AF uses a beam splitter, not the metering system.
Where did cheap come into this, BTW?
Circular polarizers are, by there nature, more expensive to manufacture, but they are not necessarily optically better filters.
It is more difficult to find multi coated filters these days.
The sun, BTW, is an issue no matter where you are. I'm not so far north that it doesn't shine.
