10-07-2009, 11:48 AM   #46
QuoteOriginally posted by Crepusculum Quote
All the shots were taken with the same settings.
You are going to be crucified for this test, you need to use M mode as using Av the camera easily freaks out and meters wrong .... you can see the kit lens is severely under exposed.
Looks like the polariser is your enemy!
10-07-2009, 11:56 AM   #47
I called Pentax to talk about what I was seeing. The gentleman wasn't that helpful and said he did not think there was an issue. then when I mentioned that I had posted my results on a forum he seemed to lose as respect in my opinion at all.
10-07-2009, 11:58 AM   #48
QuoteOriginally posted by Alfisti Quote
You are correct I will run another test right now.
10-07-2009, 12:14 PM   #49
I'd call Larry King to discuss pentax lenses before calling Pentax themselves ... you'd get a more intelligent answer.
10-07-2009, 12:17 PM   #50
mk07138's Avatar
I really think that your first test identified the problem. I think that your polarizer is defective. As for the different exposures I've always had different lenses that expose differently when using auto settings. Seeing as how your original problem was related to blurry soft images and not exposure I'd focus more on that than the fact that your kit lens underexposes compared to the DA* when using AV.
10-07-2009, 12:29 PM   #51
vizjerei's Avatar
If you look at the quality of the DA* vs. DA, it is very hard for me to notice much a difference in quality of the picture, but the DA* does take a slight edge, but it's not as much as I thought it would.
The selling point of DA* 16-50 is the larger aperture and weatherseal, when you step down to f8, most of the lens preform quite good for sure (if not you should just throw it away )
10-07-2009, 12:30 PM   #52
Ok I took some more shots, because I was concerned that the DA* was not 'that' much better then the kit lens. These I did in manual mode (as was suggested). Wireless 3 second delay shots.
Manual Mode. 1/1250 sec @ F/5.6. ISO 200. Spot Metering.
DA* 16-50mm
!00%
DA 18-55mm
100%
It seems that the DA lens is still underexposing a bit. The quality of each shot is still not far off from each other, to the point that if I was shooting stepped down I don't think it would make a difference in which lens I choose. This is a bit dis-concerning due to the price of the DA* vs the DA. But at least that is my opinion on my unscientific test (as the Pentax rep told me).
10-07-2009, 12:33 PM   #53
QuoteOriginally posted by mk07138 Quote
I really think that your first test identified the problem. I think that your polarizer is defective. AV.
I agree with you. I might just stick to my high end B&W from now on.
10-07-2009, 12:34 PM   #54
At f/8, honestly there is bugger all difference between $100 and $1,000 lenses. The differences would be subtle in rendering, colour, contrast and fine detail as well as edge sharpness.
This is why i do not own fast zooms, the penalty in weight and size is not worth it to me.
10-07-2009, 12:52 PM   #55
Pentaxor's Avatar
the polarizer made the IQ look bad. aside from the different exposure and meter reading, there is also significant difference between the DA* and the DA kit lens IQ, I don't know if you noticed it but the DA* has more depth and contrast detail at higher apertures, and therefore is more sharper than the DA kit lens which is a bit soft, but not bad at all for a kit lens.
10-07-2009, 01:28 PM   #56
Ash
Community Manager
Ash's Avatar
Fast zooms however are designed to perform well at large apertures.
The kit lens does not do all that well at 50mm at f/5.6, but the 16-50 does - and hence the application of the 16-50 is much broader and more versatile.
One who does not use the lens in these conditions may indeed be wasting money and their backs!
10-07-2009, 02:41 PM   #57
Marc Sabatella's Avatar
My read:
- You've definitely proved the polarizer is the main problem.
- You've proved the kit lens does quite well, and like Alfisti and for the same reasons, I don't consider fast zooms worth the price or weight. The kit lens is fine when I want zoom, but I prefer smaller/lighter/cheaper primes when I want speed or I think I can eek out just a little more IQ.
- I wouldn't sweat the difference in exposure between the two lenses in Av mode. For one thing, you were metering slightly different scenes (one lens has had a wider view than the other), so you really had no reaosn to expect an identical exposure. In particualr, the differen amounts of the sky and white vehicle visble certainly affected the meter. And for another, you were pretty right at the border between clpping and not clipping, so the camera had a tough choice to make. I'd actually call the DA* shot dangerously close to being overexposed, but this is all subjective. If you consistently saw the camera choosing a full stop darker exposure on the same scene in Av mode, that would be worth noting, but that's not goign to be the case.
- When using M mode, there was barely any difference in exposure. If the DA* produced a *slightly* brighter image, most likely that's simply showing it uses better glass with a higher light transmission. There, the DA* just earned a bit of its price premium.
10-07-2009, 03:45 PM   #58
Ben_Edict's Avatar
If I follow the notes you provided, the DA* shot was exposed f/5.6 - 1/800s whereas the much darker 18-55 image was exposed with f/5.6 - 1/1600s, one stop faster - which explains the darker image and the good contrast. This makes the contrast look better and narrows the visible gap between the humble kit lens and the DA*. You can reduce the influence of perception by getting the expsoure with both lenses to the same level.
What is also very clear in your image (and I have rarely seen such a bad example), is the negative influence of the polarizer you used.
Ben
10-08-2009, 12:11 AM   #59
I have been thinking about going the prime route for a bit. It is just such a hassel to sell the 16-50 and my 60-250. Not to mention that it really would not save me any money to get the primes as the ones I was looking at are quite expensive too.
10-08-2009, 08:24 AM   #60
Pentaxor's Avatar
you're not getting the FA LTD's are you? just in case, the DA LTD's (21,35,40,70) are quite a cheaper alternative but great as well. get an FA 50 1.4 or the DA50 macro which are also very nice. and may I recommend an FA/DFA 100 macro for telephoto, I like these two because they are really have a very high IQ. 14mm is also affordable. that would leave you a DA* 200 for the longer telephoto. hope this helps.
image, k-mount, pentax lens, reduction, shake, shots, slr lens
some horrible luck here irishwhite Pentax Film SLR Discussion 2 09-04-2010 03:34 PM
Horrible Dust on my K-x sensor gut1kor Troubleshooting and Beginner Help 7 07-24-2010 07:06 PM
So horrible at ISO800 henryjing Pentax DSLR Discussion 42 04-17-2010 10:26 AM
Detroit's Beautiful, Horrible Decline deadwolfbones General Talk 37 09-26-2009 07:54 AM
My horrible LBA... Vulpix Pentax SLR Lens Discussion 4 03-07-2007 07:53 AM
All times are GMT -7. The time now is 07:12 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
