Whether you use it at 10mm or 17mm, it's always a fisheye and will always produce a lot of barrel distortion (IE with a fisheye you will always be using the fisheye effect). In landscapes, especially if you're not familiar with the area, it's easy to not see the distortion, but it's there. In an unfamiliar landscape, the only known straight line is often just the horizon. Placing that in the exact center of the frame easily masks that distortion. With other familiar objects and things with straight lines, this distortion is much more easily evident.
Compare the distortion of the
10-17mm to that of the
DA 14/2.8. Also, check out
images taken with the 10-17mm. Most of those are towards the 10mm end.
Will you be happy with the distortion? I don't know. You're really going to have to decide for yourself. I personally love my 10-17mm. It's a really fun lens that does things I couldn't possibly do with any other lens. However, I also have a DA 15mm that I'd say the same about.
As for the "clarity", I'm guessing you're asking about its sharpness, where it performs quite well. However, the optical problem with the fisheye is chromatic aberrations. The purple fringing can be particularly bad.
Oh, another nice feature of the 10-17mm FE is how close it focuses. I think you can get to like 2 inches. Every time I get that close I have to check I'm not going to run into something.
