10-06-2009, 11:46 AM   #1
insulinguy's Avatar
pentax fisheyes...
just wondering if anyone has a preferred fisheye that they like? i am about to pull the trigger and get the pentax 10-17mm but ive heard good things about the sigma 10-20 (for way less) or just jumping all the way to one of those zenikar (sp?) 8mm fixed. i see them on ebay all the time - while the pentax 10-17mm is my first choice ( i love pentax glass) the price is a bit hefty. cheapest ive see on ebay was about 400. any suggestions? thanks!
10-06-2009, 11:54 AM   #2
wlachan's Avatar
Have the Pentax and love it; smooth metal construction (inner barrels) and good sharpness, but PF is quite obvious, just like what the photozone test says.
10-06-2009, 12:08 PM   #3
QuoteOriginally posted by insulinguy Quote
i am about to pull the trigger and get the pentax 10-77mm but ive heard good things about the sigma 10-20 (for way less)...
The Pentax 10-17mm (not 10-77mm) is a FE. I don't think the Sigma 10-20mm is a FE. They are two different animals.
You first have to determine if you like the FE effect.
If you're looking for a FE zoom, the Pentax is the only one. Tokina has a similar lens (probably the same), but not for Pentax mount (no point).
Also, I don't think the Sigma 10-20mm price is "way less" than that of the Pentax.
10-06-2009, 12:13 PM   #4
blackcloudbrew's Avatar
The DA 10-17 is a unique lens, period. Just do it, you will not regret it.
10-06-2009, 12:23 PM   #5
insulinguy's Avatar
well - i have seen the pentax for 439 on ebay and the sigma for under 300 so...thats way less to me. but odds are ill just jump on the pentax - i havent seen one image from it that i didnt like!
10-06-2009, 12:31 PM   #6
I have the Pentax 10-17mm FE and the Sigma 10-20mm - they are totally different from each other.
I don't use the FE that much, but it's great for urban abstracts but hopeless for landscapes unless you want that level of distortion. The Sigma is a rectilinear lens so does not exhibit the distoritions.
The Sigma is my landscape lens of choice.
10-06-2009, 01:05 PM   #7
Where are you seeing the Sigma for under $300? I got mine at the lowest price around, for $429 a couple months back.
That said, the Pentax is a fisheye and the Sigma is rectilinear (like the Pentax 12-24). Not a fair comparison.
10-06-2009, 01:13 PM   #8
daacon's Avatar
QuoteOriginally posted by Big G Quote
Hopeless ??? this is from the DA 10-17 ... keep it level watch the lines on the edges and you get an image with very little distortion. Now tilt it up or down and the effect becomes very pronounced (which is fun as well).
Exposure: 0.006 sec (1/160)
Aperture: f/9.0
Focal Length: 10 mm
Exposure: +0.60
ISO Speed: 100
Exposure Bias: 0 EV
Flash: Off, Did not fire
[IMGWIDELEFT]http://farm4.static.flickr.com/3524/3965665771_f95811879e_b.jpg[/IMGWIDELEFT]
10-06-2009, 01:14 PM   #9
insulinguy's Avatar
granted - it was a sigma being sold from an indivdual and not BUY IT NOW - but it was under 300. most of them are more - true - but ive seen it for less. and i dont mind the distortions at all - but thanks for making the disctintions between the lesnes as i was going to buy it for landscapes. i would probably use it 80% of the time though to be honest - i love wide angles for portraits, street photo, urban decay and landscapes.
10-06-2009, 01:16 PM   #10
QuoteOriginally posted by daacon Quote
Exactly, I don't want to have to worry about my distortions, particularly when you have two thirds foreground, one third sky and pointing down down at a rockpool. The Sigma is a much better tool for that sort of work than the FE. You can also forget about using filters and polarisers on the FE making it even more hopeless for a landscaper.
10-06-2009, 01:21 PM   #11
Ash
Community Manager
Ash's Avatar
You may find the 10-17 not appropriate for all landscape shots, whereas the 10-20 (being a rectilinear) would suit most wide angle applications.
Using the 10-17 for landscapes, you may find yourself having to stay at the 17mm end to avoid distortions (which are least pronounced there), so there may be less flexibility - having said this it's a fun lens to have, and you can see the type of images it (and other FE lenses) can produce by reviewing this thread:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/33549-fisheye-...ye-photos.html
I have both the 10-17 and 12-24 - both totally different lenses, and although I use the 12-24 more, the 10-17 has a special place in my photography...
10-06-2009, 01:27 PM   #12
wasser's Avatar
I too think calling it "hopeless" is a little being a little harsh. It plays pretty nice at 17mm. However, one important thing to consider, with regard to the 10-17mm and landscapes, is not being able to use filters at all.
10-06-2009, 01:31 PM   #13
Yes, which is what I said above - not being able to use filters or polarisers makes it a very unwise choice for a landscape lens.
10-06-2009, 01:33 PM   #14
wasser's Avatar
True, I missed an entire sentence. :x
10-06-2009, 01:36 PM   #15
daacon's Avatar
Indeed not being able to use filters hurts for landscapes. Like Ash I have the 12-24 which I use much more often. I just took offense at the hopeless comment - that landscape I have above is without any filters and at 10mm ... so there are uses other than distortion and as mention at 17mm it is much less noticeable.
The DA 10-17 is the one lens I usually always have with me.
10-17mm, ebay, k-mount, pentax, pentax lens, slr lens
What Fisheyes are available to K10? gozerthegozarian Pentax SLR Lens Discussion 9 10-21-2008 01:28 PM
Photokina : Sigma announces 2 fisheyes lenses for Pentax ghelary Pentax SLR Lens Discussion 3 09-23-2008 10:06 AM
fisheyes make you seasick? nostatic Pentax SLR Lens Discussion 6 02-21-2008 07:16 PM
Fisheyes AV82GOLF Pentax SLR Lens Discussion 6 10-19-2007 12:31 PM
Fisheyes - Zenitar vs Pentax 10-17? Groucho Pentax SLR Lens Discussion 20 07-05-2007 06:03 AM
All times are GMT -7. The time now is 08:20 PM. | See also: NikonForums.com, part of our network of photo forums!
