Originally posted by Igilligan I am talking about metering non-A lenses in Av mode vs green button metering.
I could just be confusing the OP here...
probably
Quote:
But Lowell if you are in Av mode clicking thru the Aperture, letting the camera set shutter speed, but then have to use exp comp, how is that any easier?
no, on M42 lenses, when you click the aperture it stops down so the metering thinks there is less light, BUT with my SMC Tak 35, the metering needs +1.5 stops at all apertures, the camera just gets it wrong. I think this is why many people short the 7th pin with tinfoil.
Quote:
Are you saying that you can set the exp comp for the lens in Av mode and then no matter what aperture you set it exposes correctly? I am not seeing that at all with my lenses.
with M42 lenses yes. note in Av mode on K mount (non A) lenses, Av mode always exposes for the wide open aperture, the camera does not stop down the lens for expsoure
