10-08-2009, 08:40 AM   #1
Tokina for pentax
Hello!
I have a Pentax K110-D and I saw in more than one web of internet like ebay, fotoboom... that tokina lenses are compatible with the pentax mount. But then I phoned to one photo accesories shop and they say me that Tokina dosnīt fabricate lenses with pentax mount.
Are, or not compatible the Tokina lenses with pentax? (for example the tokina 80-400mm)
10-08-2009, 10:43 AM   #2
Wheatfield's Avatar
Well, if you buy one with a Pentax mount, then it's compatible. If you don't, or can't, then it isn't.
10-08-2009, 11:11 AM   #3
QuoteOriginally posted by Blade94 Quote
Hello!
Shop was wrong.
Tokina makes Pentax K-Mount lenses.
Seaain
10-08-2009, 11:33 AM   #4
What they really meant was that they didn't carry Tokina lenses in Pentax mount.
If I don't have it, it doesn't exist....
10-08-2009, 12:09 PM   #5
Hello!
Tokina used to make K-Mount lenses, so you can still find them in places like ebay, but the last Tokina K-Mount lens was produced in 2002 - Tokina now co-develops some lenses with Pentax, so there are 'cousin' lenses available from Pentax that are very similar to some Tokina lenses, specifically:
As of March 2009, the six lenses co-developed and released in both Tokina and Pentax versions are the AT-X Pro 12-24mm f/4.0, AT-X Pro 16-50mm f/2.8, AT-X Pro 50-135mm f/2.8, AT-X 10-17mm f/3.5-4.5 fisheye, AT-X Pro 100mm /2.8 macro, and AT-X Pro 35mm f/2.8 macro. The last Tokina lens released before the collaboration was the 28-70mm f/2.8, in 2002. The currently available Tokina own-designed lenses are the 11-16mm f/2.8, 80-400mm f/4.5-5.6, 16.5-135mm f/3.5-5.6 and 28-80mm f/2.8.
10-08-2009, 12:15 PM   #6
Well, yes and no.
Tokina currently has a joint development/marketing agreement with Pentax, which means that many of Tokina's high-end lenses DO NOT come in Pentax mount -- but there's a Pentax-branded twin.
For example, there's a Tokina 50-135mm f/2.8 for Nikon and Canon, and there's a Pentax 50-135mm f/2.8 that's basically the same lens. There is no Tokina 50-135mm for Pentax -- you're supposed to buy the Pentax version. Same is true for 16-50mm, 12-24mm, 10-17mm fisheye, and so on.
But there are other Tokina lenses available for Pentax mount. The 80-400mm is one example, and it may be the only one in current production (is it?). There are older ones too, from before the agreement with Pentax.
10-08-2009, 12:23 PM   #7
Thanks everybody!
I was thinking to buy one tele zoom lens, and I see the tokina 80-400mm, that isnīt bad nad it have good price.
Do you know any other tele not so expenssive?
Thanks!
10-08-2009, 12:55 PM   #8
Douglas_of_Sweden's Avatar
QuoteOriginally posted by nater Quote
Wikipedia ain't always a fantasticaly detailed source.
To be more specific, Pentax developed the
DA10-17 fisheye
DA*16-50
DA*50-135
DA35ltd macro
DFA100 macro (slightly changed optical formula based on F/FA100 macro, see Pentax Short Telephoto Prime Lenses)
Perhaps Tokina contributed somehow, but Pentax is the only company name on the patents, so I doubt that. It is more likely that Pentax has licensed the optical designs to Tokina. A quite common sort of deal historically between different lens makers. Tokina manufacturers their own versions, apply their own coating, and you don't get SDM and weather resistance on the DA* lenses. Also, at least the Tokina version of the 35ltd is very plastic and far from limited build quality. Obviously in this deal Pentax must be making money on Tokinas sales to Canikon users who buy these lenses and Tokina are forbidden to sell them with K mounts. Pentax would be a fool to let someone compete with low budget versions of their own designs.
In the same way, but vice verse, the DA12-24 is a Pentax build of a licensed Tokina design. Probably Tokina get their share of Pentax profit on that lens.
Simple as that. Lens history is full of this. But they would never talk openly about the details of the economical agreements.
10-08-2009, 02:53 PM   #9
QuoteOriginally posted by Douglas_of_Sweden Quote
...Perhaps Tokina contributed somehow, but Pentax is the only company name on the patents, so I doubt that. It is more likely that Pentax has licensed the optical designs to Tokina...
Thanks for the info, I didn't know that. Sounds like someone should update that wikipedia page.
10-08-2009, 06:29 PM   #10
Someone on DP Review Forum contacted Tokina and were informed that Tokina only produces lenses in mounts that have at least 5 percent of the market. Pretty reasonable considering their small size as a company. Anyway, Pentax has been way below that since I can remember.
Also, as mentioned above, if they have licensed Pentax's designs, they certainly couldn't compete with them with those particular designs.
10-08-2009, 10:52 PM   #11
I believe that Hoya owns both Pentax and Tokina, so if they manufactured lenses under both names in Pentax mounts they'd be competing against themselves
10-09-2009, 12:07 AM   #12
Arjay Bee's Avatar
The 80-400 AT-X comes in three versions - the original and the second were made in pentax mount but the most recent which is optimized for digital is only in Canon and Nikon mounts.
The first two are still good lenses second hand if they can be found.
10-09-2009, 01:19 AM   #13
QuoteOriginally posted by little laker Quote
Well, last thing I read about it (after much gossip without evidence) appears to support some sort of informal economical relationship that is not eassy to understand if you are not into Japanses business culture. But even so, I'm sure each board and director wants to report the best economical numbers, so Pentax could not allow someone to aim their own sword at themself. If they also belong to the same informal Japanese economical structure, all partners are probably even more interrested in avoiding internal competition.
10-09-2009, 01:20 AM   #14
I thought about doing it, but I would need the time to dig up (again) the patens and other references, since I think it is useless to change anything in wiki without adding real references.
10-09-2009, 06:16 AM   #15
axl
axl's Avatar
Has anybody here any experience with Tokina ATX PRO 80-200/2.8?
I have read couple of reviews on it on the net, mostly good. Everybody seems to like the build of the lens. I just wonder how does it compare to Sigma 70-200/2.8, Tamron 70-200/2.8 and DA*50-135/2.8???
any info will be usefull,
thanks
Peter
k-mount, lenses, mount, pentax, pentax lens, slr lens, tokina
DC motor tech from Tokina? Tokina and Pentax relationship? kales Pentax News and Rumors 68 10-14-2010 12:34 PM
For Sale - Sold: Tokina 20-35mm f2.8 AT-X Pro, Tokina 28-80mm f2.8 AT-X Pro, Tokina 100-300mm f photobizzz Sold Items 7 01-30-2009 06:04 PM
Tokina/Pentax 11-18 F2.8 ??? xGene Pentax SLR Lens Discussion 3 09-08-2008 04:04 PM
For Sale - Sold: FS: Tokina 17mm, Tokina 100-300mm, Sigma 28-200mm time-snaps Sold Items 2 07-24-2007 03:47 PM
All times are GMT -7. The time now is 07:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
