11-13-2009, 07:56 AM   #16
Thank you
Thank you for all the comments, I brought into repair, and now works perfect. they said previous owner must drop or bang, so who knows...next time i have to check what its real condition, but anyway, thx a lot for help!
11-13-2009, 09:25 PM   #17
tvfd911's Avatar
Glad to hear you're happy with it now
12-16-2009, 09:29 AM   #18
I have a M 50/2 that needs adjusting as it is just a hair off infinity. However after reading a few threads and searching around, I still cannot remove my front ring I am using a soft rubber mat with the bottom of a bottle but it just won't budge - even after a few drops of WD40. Tried turning the regular direction - CCW and also the opposite, just in case.
Can anyone point out what I am doing wrong? Cheers!
12-16-2009, 10:21 AM   #19
Just1MoreDave's Avatar
The trim ring should come off just like a filter does, because they use the same threads. It should be CCW. Sometimes I've used a toothbrush to clean dirty threads so grit doesn't cause excess friction. You've already tried drops of WD40, my other trick, just drops applied only to the point where the threads meet the ring. If your mat slips, you could try a different tool. Make sure the threads are not damaged and the filter ring isn't dented. If the filter ring isn't round, nothing will unscrew. Some people give up and drill holes in the trim ring for the tips of needlenose pliers. I hate to do that so I just keep trying. The trim ring might be aluminum or plastic depending on its age.
Some trim rings appear to have slots for a tool with really thin blades. Here's a photo:
Not every trim ring has slots. You'd have to improvise a tool, but it would be a non-destructive alternative to drilling.
k-mount, lens, pentax lens, pentax-m 40mm f2.8, slr lens, smc pentax-m 40mm
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
For Sale - Sold: Pentax SMC DA 40mm F2.8 Limited Pancake Lens frank Sold Items 3 09-07-2008 07:16 PM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 11:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
