10-20-2009, 08:11 PM   #1
Experience with filters on the DA 15mm?
I just ordered the 15mm and 70mm Limiteds
I was thinking about getting a filter kit to use on these but was curious if I'd have vignetting issues on the 15mm. The photozone review notes that vignetting is an issue on this lens until F/8 and was wondering how much a thicker filter like a polarizer will worsen this.
Not too worried about the 70mm as I understand vignetting is less of an issue on this lens and I'd be less likely to put filters on it anyways.
Your thoughts are appreciated.
10-20-2009, 11:04 PM   #2
apemen's Avatar
Great buy JamieP, congrats.
dpreview.com says
"The lens can be used with normal thickness (as opposed to slim) polarizers without vignetting, making for a far more economical solution than the slimline 77mm filters required with most wideangle zooms."
10-21-2009, 12:38 AM   #3
Spock's Avatar
Consider a Hoya Pro-1 HMC filter. It is a slimline filter and as a bonus the multi-coating is a close match to Pentax's own SMC.
70mm, filter, filters, issue, k-mount, lens, pentax lens, slr lens
DA 15mm LTD and GND Filters trublubiker Pentax SLR Lens Discussion 5 10-24-2010 02:42 AM
using filters with DA 15mm Limited olenl Pentax SLR Lens Discussion 11 08-21-2010 08:31 PM
For those with a DA 15mm who use Cokin P sized filters... Andrew Faires Pentax SLR Lens Discussion 0 02-16-2010 07:29 PM
Experience with HOYA PRO 1 DIGITAL Filters? dmdctusa Pentax Camera and Field Accessories 8 11-10-2009 12:50 PM
Pentax DA 15mm -and use of filters phb49 Pentax SLR Lens Discussion 0 07-17-2009 03:06 AM
All times are GMT -7. The time now is 04:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
