Originally posted by seacapt My kid's Fall baseball team was in a tournament last weekend. They were the absolute under dogs yet took second place when it was all done. All the games were played either under the lights or in heavily overcast conditions so I wound up with no pictures. I use a Tamron 75-250 Adaptall f 3.8-4.5 or a Pentax FA 80-320for most of their games but I need something that I can use in adverse lighting conditions. Any Suggestions?
This is not a easy answer. I would try your
Tamron 75mm-250mm f/3.8-4.5 adaptall-2 (104A) and pre-focus and try to see what you can get out of it. Again, try
high ISO and I
frequently use TAv for action shots such as f/4.0 and speed 1/500 sec and set auto-iso from 200 to 3200. And adjust as necessary in TAv with
shutter speed and apertures trying all combination f/4.5, f/5.0 to find the sweet spot. Find the shutter speed matching the game and the scene of lighting and pre-focus.
Also, I am no strobist, see if a strobe can help you instead of fast lens. If you have the
Tamron p/k-a adaptall-2 adapter, your PTTL or auto flash will be your friend for the extra juice in the picture. I used bounced flash but for your game, I will blast it straight on when necessary at unfavorable dim night setting. For bounced flash needing an amplified reflector, I have used quite satisfactory with
Spectra Flash Light Diffuser as reflector with silver coating for amplified reflection from strobe at a bounced angle.
For faster glass in Tamron adaptall-2, I see that you are in the similar boat like me who have sought after Tamron good adaptall-2 SP glasses, I highly recommend
Tamron SP 80-200mm f/2.8 adaptall-2 (30A) and the
Pentax F-1.7x AFA.
With
in late afternoon around 5:30pm in dim lighting
1/100 sec, f/5.0, 180mm, iso 320, +0.3 Ev
1/125 sec, f/5.0, 180mm, iso 320, +0.3 Ev
1/100 sec, f/4.0, 135mm, iso 250, 0 Ev
I have not tried the combination with 1.7x AFA yet and I think it should work well together along with a good mono-pod for the weight support. But first thing first, try your long zooms with high ISO and TAv
75-250mm f/3.8-4.0 (
104A) on right
35-80 f/2.8-3.8 (
01A) on left
0.3 sec, f/4.0, 75mm, iso 640, 0 Ev
quite a bad sample to post but I don't have more test shots to convince you to try
give this zoom a chance to work at night
Thanks,
Hin
