10-24-2009, 02:19 PM   #1
Decision Sigma 70 -200 or Pentax SMC FA*star 80-200mm/f2.8 ED IF Lens
Hi. Im new to this forum and had my first SLR -Pentax K10D Grand Prix for 2 yeas now. I finally feel confident to sell of my kit lenses and upgrade to something a bit better.My photography is of personal use so not selling or printing too much.Although I have someone interested in my work of his store.
I have been looking at buying a Sigma 70-200 f2.8 for Appx $1100 Australian (1000US) but now have come across the pentax 80-200 f2.8 at $1900 AU or (1769 us) second hand. My use for the lens would be a bit of motor sport, portrait and general photography. I am after a bit of guidance on who uses what and what is suitable. I plan to stick with pentax cameras and will upgrade one day.
Any advice would be welcome.
John
10-25-2009, 12:46 AM   #2
I have been doing a bit of research today and still undecided. A lot seem to have problems with the Sigma 70-200. Does the Pentax become a 120-300 when on a Digital SLR.
John
10-25-2009, 12:57 AM   #3
axl
Hi John,
first things first, I never owned any of those two lenses, but I had a chance to try Pentax FA*. It's massive lens, and really heavy (for this category anyway). It has great IQ but many who tried Sigma 70-200 say it is very comparable. Now, as you said, some had problems with Sigma lens. This usually relates to the new HSM version. Honestly, I haven't read anything negative about the older one.
good luck choosing...
as for your other question, no. No lens becomes longer. 80-200 stays 80-200 but due to cropped sensor frame, the effective FOV is that of 120-300 compared to FF or film cameras.
BR
Peter
10-25-2009, 01:27 AM   #4
Ash
Ash's Avatar
Don't be confused by the 35mm equivalent focal lengths. The lens gives the same magnification, but the digital sensor crops some of the full-frame image off, giving you less in the frame as captured by your K10D.
Now as for the FA* and 70-200 comparisons, believe me when I tell you this, I have agonised over the FA* for a while, and after having two opportunities to grab one I decided to pass both times - which made me feel a touch of remorse at each opportunity.
This is partly because of the reputation the FA* has but also its unrivalled build quality. I've held one once, but never got the chance to test it. I personally don't mind the weight but the IQ, even though it is absolutely excellent, is apparently not a great deal ahead of either 70-200 option available on the Pentax.
I would suggest that if you're considering the 70-200 by Sigma (the newer HSM version), then consider the Tamron that was released soon after the Sigma. It is just as good, if not better, than the Sigma in IQ and reasonably well built - both are heavy and large, but not more than the FA*. They are both plastic, though, whereas the FA* is metal.
If you have the opportunity to buy the older Sigma 70-200 EX DG version (not HSM), I would say this would top the bunch for reliability and IQ. Most people here vouch for this (contrary to what Sigma would like to promote about their HSM version).
So with this in mind, give it good thought - if you are happy to drop the funds, the FA* is a lifelong keeper, whereas the Tamron (or Sigma) 70-200 is better value with a downer on the build quality (which may be important to you in your situation).
10-25-2009, 03:29 AM   #5
Thanks Guys for your reply. I have been in the market for a lens for a while. I like the FA only the cost of 2k AUS plus customs may make it a bit expensive. I wouldnt mind looking for a pre HSM Sigma 70-200 if I could find one. Just the images I have seen taken with the FA are amazing and havent found anywhere similar quality with th Sigma or Tamron. Would love to hear from some Sigma and FA owners and see some images. The FA im looking at could sell in the mean time but thats luck.
John
10-25-2009, 04:49 AM   #6
Ash
Ash's Avatar
Keep your eye out for one as they pop up from time to time...
10-25-2009, 05:33 AM   #7
I own the oldest version of the Sigma (1.8m minimum focusing distance with an aperture ring and no digital coatings). It's constructed mainly of metal, overall the build is very solid.
I haven't found a direct comparison as far as IQ goes but photozone have reviewed both. The Sigma was reviewed on a Canon so you can't compare the actual MTF scores but you can still get a general idea of how each lens performs.
Sigma 70-200 EX DG (same optical construction as the non-DG version)
Sigma AF 70-200mm f/2.8 EX APO HSM DG - Lab Test Report / Review
Pentax FA* 80-200
Pentax SMC-FA* 80-200mm f/2.8 [IF] ED - Review / Lab Test Report
Judging by those charts the Sigma has the edge at the wide-end with things pretty even in the middle. The Pentax beats the Sigma at 200mm. The Sigma performs more evenly across the whole frames wide-open at all focal lengths while with the FA* there is a bigger difference between centre and corner sharpness.
The above pretty much mirrors my own experience with the Sigma, up 180mm it's very sharp wide-open, not quite so at 200mm but definitely still very usable.
10-25-2009, 07:12 AM   #8
axl
QuoteOriginally posted by campdog Quote
John
what's the exchange of AUS$ to GBP£ ???
I know of FA* in excellent condition (after quick evaluation) for £699 (I think, but it may be £799). I'd post it to you and declare it as present. Mind you, the lens is really hefty and as trackable parcel it could be costly...
BR
Peter
10-25-2009, 09:27 AM   #9
Marc Langille's Avatar
I know this might not help... I normally shoot with my FA* 80-200/2.8 at around F/5.6 or slightly higher - that's enough DOF for the type of shooting I do with it - Civil War Reenactments. I rarely do any shots wide open. No issues with clarity!
Images - first at 80mm:
Link to EXIF
Then at 200mm:
Link to EXIF
Now back at 80mm (but at F/8 since I want the entire head in focus):
Link to EXIF
Unfortunately my FA* 80-200/2.8 doesn't see a lot of use for the kinds of subjects I spend the most time at photographing: nature and wildlife. I buy the faster lenses for their optical qualities and build excellence that is normally inherent with those models, etc. as some of the more desirable characteristics. I do agree with Ash on the build quality: the FA* 80-200/2.8 is a tank. Sigma's EX line seems to be quite good, but mine is limited to the Sigma 500/4.5 EX DG lens - incredibly good build.
Regards,
Marc
10-26-2009, 12:29 AM   #10
QuoteOriginally posted by axl Quote
BR
Peter
I just checked about AU$2.oo to the pound. Like you say getting it here might be expensive. Maybe worth looking into. A confirmed price and condition would be appreciated.
John
10-26-2009, 02:21 AM   #11
Marc, those images are spectacular. It what I want in a lens. Made my mind up, now I need to find one and get it here without the wife killing me.
Could the lens be used for flower close up ets.
John
10-26-2009, 11:50 PM   #12
Well wouldnt that stuff ya.I decided on the Penatx 80-200 and just went to buy it and its been sold.Thats what happens when yo bugger around trying to decide on something.Now I can look at a 300mm f* 4.5 for about $1100 aus or wait for another 80-200 .It went for $1900 AU.
John
10-27-2009, 12:13 AM   #13
Ash
Ash's Avatar
AFAIK, this one is still available for a similar price...
https://www.pentaxforums.com/forums/photographers-marketplace/77649-sale-pent...case-more.html
10-27-2009, 12:43 AM   #14
Thanks Ash, I have sent a PM as well. Got an email from ebay and another one coming up in a couple of days.
John
10-27-2009, 02:30 PM   #15
Mike.P®'s Avatar
I rather like my Sigma MK I 70-200mm f2.8 APO EX. (NON HSM)
bit, f2.8, k-mount, lens, pentax, pentax lens, photography, sigma, slr lens
new sigma 50-200 compared to pentax 50-200mm George S Pentax SLR Lens Discussion 2 05-21-2011 06:52 PM
1.4x Teleconverter for Pentax K7 and smc PENTAX DA Star 200mm F2.8 ED (IF) SDM imagesforyou Ask B&H Photo! 20 09-19-2010 10:12 AM
For Sale - Sold: SMC Pentax DA*(star) 200mm F2.8 [IF] SDM (Worldwide) Syb Sold Items 19 07-13-2010 12:19 PM
Travel Lens Final Decision : Pentax 17-70 SDM Vs Sigma 18-250 HSM Christopher M.W.T Pentax SLR Lens Discussion 34 02-22-2010 10:54 AM
Lens decision: Pentax 16-45 and 50-200 combo OR 18-250? sweetpapa Pentax SLR Lens Discussion 30 12-07-2007 02:12 PM
All times are GMT -7. The time now is 08:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
