10-26-2009, 06:53 AM   #1
brosen's Avatar
What are the Pro and Cons of using an FA lens with the K-7 instead of a DA lens ?
I need a PRIME lens in the 30mm to 40mm range super fast, ideally f/1.4 or f/1.8.
Initailly I bought the Sigma 30mm f/1.4, it a GREAT LENS but I can not override the AF to MF from the focus ring, I have to move the switch in the camera itself, very inconvenient.
So I am thinking now using one of the Pentax FA lenses, like the FA 31mm f/1.8, but I do not know what I am loosing by doing that ?, what are the main differences between DA and FA ?
Right now I have the DA L 21mm f/3.2, it's a great lens, small and fast, but in low light situations it's not very good.
Thanks
10-26-2009, 07:57 AM   #2
I don't believe FA lenses have quickshift like your DA21. I think you'll have to use the on-body switch to go from AF to MF with them as well. (It's been a while since I used my FA50, so I can't be sure.)
10-26-2009, 09:17 AM   #3
Quickshift is not available on the FAs. I have the DA 21 and 70 which I like a lot. I also have the FA31 which I also like a lot. I tend to use either autofocus or manual focus - I don't really take advantage of the quickshift so it is not that big of a deal for me.
The DA lenses have different/extra coatings to eliminate reflections from the sensor.
The DA lenses are a bit smaller.
You can still get some of the FA limiteds which were made in Japan. QC seems to have been better on those. I have sent my DAs back to Pentax to repair loose lens barrels. Quite a few folks have had an issue with this.
FAs are faster and are all very good wide open.
10-26-2009, 11:31 AM   #4
RawheaD's Avatar
FA 31 doesn't have quick shift, as has been noticed. Besides that, there's nothing you will lose, and everything you will gain. It is just a beautiful lens.
10-26-2009, 11:33 AM   #5
Quick shift can be simulated on non-quickshift lenses with decoupling AF button from the shutter and pressing bayonet lock button (easily with your ring finger). Try at your own risk (but I use it regularly with my FA 50).
10-28-2009, 09:23 AM   #6
QuoteOriginally posted by RawheaD Quote
But the Sigma 30mm is a great lens as well. In Canon-land, this is the generally prefered "normal" lens for crop users (compared to the MUCH more expensive Canon 35mm f/1.4 L)
If you're happy with the Sigma 30mm, keep it! Not sure if you'd notice a whole ton of difference between it and the 31 Limited (especially in "handling" as both lack quick-shift focus)
30mm, da, da lens, f/1.4, f/1.8, fa, fa lens, k-mount, lens, pentax lens, slr lens
In-Body SR vs. In-Lens SR Pros and Cons? uchinakuri Troubleshooting and Beginner Help 32 09-23-2010 09:42 PM
Pro Photographer G. Lewis (Shutterfinger) Chooses... the kit lens? Aegon Pentax SLR Lens Discussion 10 08-30-2010 02:23 PM
For Sale - Sold: [US] Pro-Master 18-200mm AF XR Lens cathynwv Sold Items 1 02-19-2010 06:40 PM
For Sale - Sold: FS: Raynox DCR-2025 PRO 2.2x teleconverter lens kit domozitolk Sold Items 0 01-05-2009 02:46 PM
Pro lens dufruf Pentax SLR Lens Discussion 0 05-09-2007 11:16 AM
All times are GMT -7. The time now is 11:04 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
