10-26-2009, 01:14 PM   #1
LeDave's Avatar
Using filters with DA Limiteds?
I have a 35 LTD Macro and a 21 LTD and I am wondering if it's possible to use filters on these without causing vignetting? I see that the hood is so tiny on the DA 21 LTD, and I'm afraid if I add a filter on top of the hood, it will cause vignetting. I only want to put a filter on so I can protect my lenses, I am very paranoid on dust being on the front element although it's easily cleaned with a rocket blower. I would rather clean the filter with a rocket blower instead.
Do you guys use filters for your Limiteds?
10-26-2009, 01:31 PM   #2
For a protective filter, the 21mm Ltd takes a 43mm on the inside of the hood. Works quite well. Dave
10-26-2009, 02:30 PM   #3
wtlwdwgn's Avatar
I use a Skylight 1B on my DA 35 Ltd and it works fine.
10-27-2009, 04:28 PM   #4
Finn's Avatar
You can also take the hood off the 21 and use 49mm filters. If you want a hood then, you'll have to use a third-party one.
10-28-2009, 04:58 PM   #5
I got a 49mm B + W rubber hood..works great. Get a slim/thin polarizer just to be safe.
10-28-2009, 06:40 PM   #6
I have the DA 35/40/70 and you can use 49 mm filters on any of them without vignetting. The hoods on the 40 and 70 just screw on to the filters. With the 35, you have difficulty using a polarizer with the built in hood. Basically have to turn it and then pull out your hood, but otherwise no problems.
blower, da, filter, filters, hood, k-mount, ltd, pentax lens, rocket, slr lens
For Sale - Sold: Trade: My 77mm filters for your 72mm filters (CONUS) loveisageless Sold Items 0 10-02-2010 12:29 AM
Lens caps and filters for DA Limiteds? Yohan Pamudji Pentax SLR Lens Discussion 10 04-22-2009 09:07 PM
DA or FA limiteds? coloseu Pentax SLR Lens Discussion 14 02-24-2009 10:18 AM
filters on the DA limiteds soccerjoe5 Pentax SLR Lens Discussion 3 09-01-2008 04:48 AM
All times are GMT -7. The time now is 07:26 AM. | See also: NikonForums.com, part of our network of photo forums!
