02-14-2013, 11:23 PM   #16
awaldram's Avatar
The F50 1.7 has a felt damper.
This damper become poluted with grease/dust leading to binding and grittiness when focused.
I quick and dirty solution my work .
sit the lens flat on a surface (very important so as no to spill liquid onto lens elements)
wholst rotating the focus mechanism flood the crack with a hi class evaporating degreasant liquid (not to much but enough to run through)
slowly the AF shoudl free up as the dust and grease is flushed.
WARNING
Do this wrong and liquid will run over the elelments leaving a residue when evapourated , you will then need to stip and clean the lens
On the plus side that only other soltuion to the the above is strip and clean lens so yo ulose nothing.
02-17-2013, 10:30 PM   #17
Culture's Avatar
QuoteOriginally posted by Asahiflex Quote
Turn the focusing ring by hand (when the lens is not attached to the camera). Is focusing harder at certain distance settings while focusing?
I followed your advice. The focusing ring was very free and there was no noise.
I then put it back on the camera. The grinding noise was gone. I dont know if it was fluke solution.
But I will keep my eye on it to see how it goes.
Thanks for the advice.
focus, k-mount, noises, pentax lens, pentax-f, slr lens
k-7 video noises normal? dedmozaj Video and Pentax HDSLRs 15 07-31-2010 11:17 AM
Pixels and noises and full frame and all Nubi Photographic Technique 2 12-28-2009 04:11 PM
K20D grinding noise on turn-on ??!! mrpink Troubleshooting and Beginner Help 4 09-06-2009 07:20 PM
k10 vs k20 reg noises filorp Pentax DSLR Discussion 12 01-14-2009 02:46 PM
Odd noises fron K10D Billgscott Pentax DSLR Discussion 4 09-09-2008 08:44 AM
All times are GMT -7. The time now is 01:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
