Originally posted by jmc7104 ..... Shooting wildlife with a camera is no different than shooting with a gun. The larger the bird the easier it is to hit and the closer you can get the better luck you will have.
I disagree, it is a lot harder to photograph something than it is to kill it.
Quote: Even with a 300mm-400mm lens and camera on tripod, shooting from blind 15, 20ft away cann be trying with smaller flighty birds.
you need to consider math, in all of this.
- Your sensor is 24 x 16 mm (w x h)
- the image size on the sensor is defined (when distance is much greater than focal length) as
Image size = subject size / subject distance * focal length.
COnsider my chickadee.
the image is about 20mm, I used a 500mm lens and the subject, according to my bird books is about 140mm. To get this image size, I was about 3.5 meters away. From memory this is right, and it is also at almost the minimum focus for the 300 F4.
If I was shooting a warbler, it would only be half that size.
Quote: Also helpful to spend consideravle time around area where you are going to be shooting from. Lets birds become famular with you. jim
there is no substitute for patience.
