Not a bad lens - very conveneint superzoom, better than the first version, not as good as the newer XR or the Di 18-200 or 18-250:
Tamron 28-200 differences
The one in the lens review database is the newer XR version but many people have commented on the other versions on the forum. Basically, probably not great at 28 or 200mm and wide open, decent otherwise. I had been looking to buy a cheap superzoom like this for travel and tours where I don't want to be changing lenses.
You'll be pleasantly surprised with in-body SR with that lens, so you can actually use the long FL where it is slower. Also, you can learn which focal lengths you like taking pictures with once you use that lens for a while - you can even use programs to scan all your pictures and figure out what FLs you take pictures with most. Then you can buy a good zoom or prime in that range. Nowdays, zooms are much better than they were in the past, but old primes are still quite good, check the review database.
For better IQ, the 18-55 will be notably better, as with most smaller range zoom lenses.
