Originally posted by julia thanks a lot for all replies.
Sure Pentax has fine lenses. Maybe 6 month later i will buy DA 40mm f2.8 and/or DA70mm f2.4 and/or DA35mm f2.8 Macro etc. But this CZ/CV is the only one MF collection forever ( maybe
@farfisa
thanks, i hope this Shake Reduction feature really work on MF for daily use or walkaround. So i do not need to buy an autofocus prime lens in 40-60mm range .
thanks pentaxian ....
I've used both Zeiss ZK and Voigtländer KA lenses on Pentax K-
m body, they are indeed plug-and-play and produce great images.
As farfisa mentions, the Voigtländer Nokton 58mm is very popular here. I own it but I am thinking to also buy the Ultron, because the 40mm focal-length is a bit more useful. If will only buy one lens to start, then the Ultron would be more versatile. The size of the Ultron would work well with the K-
m / K-
x . The price is very reasonable.
The image-stabilization on the K-
x works great.
Here is an image from Voigtländer Nokton 58mm at 1/15s.
To get the best results from these manual-focus lenses, you really need to install a split-image focus-screen (replace the standard screen that comes with the camera).
