10-28-2009, 11:59 AM   #1
Observation on DA* 50-135mm AF/MF operations
Last night, I tried my DA* 50-135mm on my PZ-1p. AF was good and accurate. Then, I mounted it back on my K10D. Once mounted it, I moved AF/MF switch to MF and tried to manual focus. Here's what I noticed: manual focus was very rough (as if an FA lens is still engaged in AF mode). I was afraid of damaging the lens, so I turned it to AF right away and auto-focused it (with SDM of course) several times. Then, did manual focus again. And it was normal again, no rough feeling.
Here are my questions:
1. Has anyone experienced this?
2. Could this be the reason why some DA* owner got their lens's SDM damaged?
Luckily, my 50-135mm is still working fine. I'll never try above focus sequences again. I probably won't even use it on slot-drive only AF camera again.
10-28-2009, 12:44 PM   #2
Ash
Community Manager
Ash's Avatar
Can't say that's happened to me. I used my DA 16-50 on my then *ist D with no problems then plonked it back onto my K10D and K20D and both MF and AF worked without hitch.
You're wise in not trying again - it does sound like the screwdrive mechanism was not deactivated once put back onto an SDM-capable body, but I can't think of why.
10-28-2009, 12:47 PM   #3
Eruditass's Avatar
I have no experience with the lens, but did you change the switch on the body or the lens (if there is one)?
10-28-2009, 01:17 PM   #4
netuser's Avatar
Off topic but ... is DA 50-135 FF capable ?
10-28-2009, 01:23 PM   #5
Heard varying reports, but it's definitely usable at 135mm. Aome people say it's alright down to 80-100mm or so. Expect vignetting,
10-28-2009, 01:43 PM   #6
QuoteOriginally posted by Eruditass Quote
AF/MF switch on the lens. There is such switch on DA* lenses. After that, I even changed the switch on body to MF. It didn't help. Focusing with SDM several times helped though.
I have the feeling that SDM (combined with slot drive) in DA lens is very delicate; the tolerance for mishandling is very narrow.
10-28-2009, 03:24 PM   #7
Venturi's Avatar
QuoteOriginally posted by netuser Quote
Nope. It's fairly close with the hood removed but there's vignetting through most of the zoom range still. And that is the reason I sold mine and "down-shifted" to the Tamron 70-200/2.8 - I couldn't stand having a beautiful piece of lens that I couldn't use to full effect with my 2 film bodies.
Examples (just some test snaps):
[/end thread hijack]
50-135mm, af, af/mf, da*, focus, k-mount, lens, pentax lens, sdm, slr lens
Interesting observation on priceing... MikePerham Pentax SLR Lens Discussion 9 10-20-2009 03:34 AM
Hoya press release about European operations falconeye Pentax News and Rumors 7 08-20-2009 02:05 PM
Interesting observation........ stgmgr Pentax SLR Lens Discussion 5 01-04-2009 09:57 AM
Intersting observation...... Ed in GA General Talk 6 05-23-2008 02:11 PM
All times are GMT -7. The time now is 09:26 AM. | See also: NikonForums.com, part of our network of photo forums!
