10-28-2009, 04:42 PM   #1
F*300mm help.. parts
Hi
I need to replace bearing ball for F ring clicks..
do u know the diameter of this ball?
10-28-2009, 10:32 PM   #2
Measure the spring with a dial caliper and the ball should be a little larger. Or measure the hole with a dial caliper and the ball should be a little smaller. You can get steel balls at a bearing supply store. I don't know if they sell them that small though.
GP
10-29-2009, 04:04 AM   #3
konraDarnok's Avatar
Or you could get yourself large magnet and roll it around in the carpet you lost it in.
10-29-2009, 04:39 AM   #4
wlachan's Avatar
Just contact Pentax for it. They must have plenty.
10-29-2009, 05:01 AM   #5
Since you are in Italy, you could try Microtools of Europe.
Here is their ball bearing page. micro-tools.de
And yes, just measure the hole it fits into and find one that will just fit inside.
10-29-2009, 07:07 AM   #6
ok thx all!!
I think first af all will use a giant magnet ahuahuhua
10-29-2009, 11:27 AM   #7
maybe somebody has the repair/service manual for this lens?
or any tutorial?
10-29-2009, 12:43 PM   #8
RaduA
Guest
I bet right now you're a bit sorry for not choosing the DA* 300!
I hope you'll resolve the problem soon!
Radu
10-29-2009, 03:48 PM   #9
it is not a real problem.. F ring works... but there are no clicks..
ball, k-mount, pentax lens, slr lens
Parts? thefragger Pentax DSLR Discussion 2 12-21-2009 01:39 PM
500mm f4.5 parts roy Pentax SLR Lens Discussion 1 03-27-2007 01:01 PM
New around these parts Buschmaster Welcomes and Introductions 6 12-11-2006 03:47 AM
All times are GMT -7. The time now is 06:27 PM. | See also: NikonForums.com, part of our network of photo forums!
