11-02-2009, 11:27 AM   #1
AF in DA 12-24mm. Is this normal?
Hello.
My DA 12-24 jarrived just 2 days ago and I went to take some landscape shoots to try it.
I found that this lens is very sharp, even at f4, so I'm very happy in this respect.
But the problem I see is with its AF. It hunts a lot, even in a perfectly strong mid-morning light it can take two-three seconds or more in find a focus, specially when I try to focus to infinity or to an object farther than 4 or 5 meters away. I have a K10d, three DA, one FA and a DA*, and none of them seems to have an AF that performs that bad.
Anyone has a similar experience? Is this normal or should I return the lens as soon as possible?
Thanks in advance.
Turo.
11-02-2009, 03:17 PM   #2
Pentaxor's Avatar
did you put some filter on the lens? as far as I know, the K10D seems to hunt more as compared to the K20D/K-7. it maybe the K10D's focusing ability rather than the lens. if it would help, try your lens with another camera body aside from the K10D just to validate your findings.
btw, I have the DA12-24 and I tried shooting it indoors with the K-7 under tungsten lighting and it focused practically as fast as my faster lens.
11-02-2009, 04:20 PM   #3
filorp's Avatar
QuoteOriginally posted by Pentaxor Quote
yes its true with k10 and wide angle lens you'v got beeeeg hunting, it was main improvement at k20...
11-03-2009, 04:03 AM   #4
Ex Finn.'s Avatar
For what it is worth, on K100D the lens focuses fast.
Cheers. Mike.
11-03-2009, 12:59 PM   #5
creampuff's Avatar
The problem is not with the lens but the camera body.
11-04-2009, 05:21 AM   #6
I have attached to the lens a B+W UV filter, but I have tried focusing without the filter and the result is the same.
Creampuff, so you do think that is normal that the body hunts a lot when focuses to infinity in daylight?
AF works fine in my DA 21 and 40 Ltd. my FA 50 1.4 and my DA* 16-50... but who knows.
I prefer to keep the lens as sending it to be serviced is time consuming and the pictures it produces are simply stunning.
I will try the lens in other camera if I have the chance.
Thanks to all for your help.
af, da, focus, k-mount, lens, pentax lens, slr lens
Real world shootout Pentax FA* 24mm F2.0 vs Sigma 24mm EX DG F1.8 NaClH2O Pentax SLR Lens Discussion 8 03-18-2008 05:30 AM
All times are GMT -7. The time now is 01:20 AM. | See also: NikonForums.com, part of our network of photo forums!
