Originally posted by rkt Marc... I would assume the digits are sufficiently distinct for the K200D AF sensor... otherwise... at the same aperture (2.8) shouldn't the Tam 90 have shown some focussing issues as well?
It's not a question of whether the digits are distinct or not. The issue that the AF sensor is much larger than the red dot - it's about the szie of the entire center bracketed area. So the camera might legitimately to focus on *anything* within that area. The digits might be perfectly clear, but if the lines in front of them are also in range, the camera might well choose to focus on them, You have no control over this - none whatsoever. The camera will choose whatever it feels like choosing within range of that sensor. Sometimes it might choose something closer, sometimes it might choose something farther away. That's why you might get different results each time you do the test, and why the 90mm might have happened to appear produce different results than the 17-50.
Quote: with the charts printed and pasted flat on a wall
How, then, did you manage to shoot them at a 45 degree angle like the instructions clearly say, then? Or was this a 3-D test chart that really was designed to be shot straight on?
Rather than continually repeating various different flawed test and trying to rationalize what miht or might not be explaining the results, save yourself a tremendous amount of grief and do the test properly in the first place. A correctly performed focus test shows you *instantly* whether you have a problem or not. An incorrectly performed one does nothing but waste time and cause confusion.
