If you select the focus point on the k20 you can trap at that focus point, I believe. Unfortunately, the k10 will only use the original snap-in-focus, which works only with manual focus lenses. The first thing off the wall I tried with the DA* 50-135 was to set the lens to MF and the body to AF.S. No joy. The whole camera went into manual focus.
So, here is what you need
- A manual lens for any Pentax AF camera, film or digital
- With the k20, an AF lens with its switch in MF will also work
- Set the camera to AF.S (single - only fire the shutter when focus is obtained)
- The camera will now only take an image when the focus indicator (green hexagon) lights up.
