11-08-2009, 06:28 AM   #1
overexposure with Metz flash, K20D, and 50mm 1.4 Super Tak
Hi! I've been experimenting with a 50mm 1.4 Super Tak lens on my K20D. It's in AV mode and works fine without flash. I do have to bump up the exposure 1/2 a stop to get a balanced exposure. But when I am using the flash, a Metz 58 AF-1, it overexposes by about 3 1/2 stops. I can get a decent picture by dialing in -3 EV to the flash. The flash is being bounced by the way. I haven't tried direct flash yet.
Any tips on what I'm doing wrong? This is the first time working with a manual lens like the Super Tak. I love the images I get without the flash though!!!
11-08-2009, 06:46 AM   #2
Lowell Goudge's Avatar
does your foash have an auto setting? If not, you can't use auto exposure modes with a flash and either K (not KA) or M42 mount lenses. P-TTL flash cannot work because it does not know the aperture of the lens to make the calculations it needs.
Flash photography with M42 lenses I find works best on *istD because that body supports TTL and P-TTL.
True TTL has a sensor reading light directly off the flim/sensor plane and therefore does not need to know th e lens aperture.
Only the *istD and DS support TTL.
If your flash does not support auto mode with it's own sensor, the only other option is full manual flash.
11-08-2009, 08:25 AM   #3
problem
i've tried in auto and pttl
11-08-2009, 09:12 AM   #4
P-TTL wont work, the flash will fire at full power
in auto, you will need to make sure the flash is set to the same ISO and aperture as the lens (aperture) and camera (ISO)
then in auto the flash's own sensor should regulate power
11-08-2009, 12:50 PM   #5
lens
i will try this in Auto with the ISO and f-stop dialed in. i just switched it to Auto before and hadn't adjusted anything else. Thanks!
50mm, exposure, flash, k-mount, k20d, lens, metz, pentax lens, slr lens, tak
Super-Tak 50mm/1.4 versus Leica Summilux 50mm DanielT74 Pentax SLR Lens Discussion 47 01-19-2011 11:10 PM
Help ID my Super Tak 50mm 1.4 akfreak Pentax SLR Lens Discussion 58 01-03-2011 11:37 AM
For Sale - Sold: [US] K20D, Metz 58 AF-1 Flash, FA 50mm 1.4, Tamron 17-50mm 2.8, Tamron 18-250m jasonfen Sold Items 11 06-20-2010 06:32 AM
For Sale - Sold: K20D, 18-55mm, DA 50-200mm, FA 50mm/1.4, Metz flash, Remote, Sandisk Cards and blip Sold Items 18 04-18-2010 01:17 PM
All times are GMT -7. The time now is 03:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
