11-08-2009, 10:59 AM   #1
kristoffon's Avatar
why are filters so hard to clean?
I have a set of Hoya filters that I use maybe 5% of the time yet they are impossible to clean. My lenses are easy. With a little fluid and microfiber cloth then a little brushing they are totally clean. But today I repeated that process no less than 5 times and couldn't clean this filter nearly to my satisfaction. The marks on the picture are just dirt. With each cleaning they move around but I can't seem to get rid of them. Is it just me?
11-08-2009, 11:33 AM   #2
Forum Advisor
Wheatfield's Avatar
Hoya filters are hard to clean. I've had filters in the past that were a bear this way. I just toss them into a sink of warm water and dish detergent and wash them that way. Whether this will work for your Hoya I cannot say, but it likely won't hurt to try.
11-08-2009, 11:45 AM   #3
reeftool's Avatar
Some lens coatings are just plain tough to clean and they seem to attract things. I will NEVER get eyeglasses with anti glare coatings again for just that reason, they are very difficult to get clean. They should come clean however. Perhaps the fluid you are using is causing the problem or maybe there is some sort of oily film on the filter. Some liquid eyeglass cleaners have an anti-fog agent and that probably shouldn't be used on a lens or filter. I use a microfiber cloth and a little distilled water only and get better results than with any fluid I have ever purchased.
11-08-2009, 12:23 PM   #4
Ash
Ash's Avatar
Yes, I can attest to this too.
Doesn't matter whether it's the Hoya HMCs, S-HMCs or B+W MRCs (which are supposed to be easier to clean than the straight B+Ws), they're all dust magnets and frustrate the perfectionist. Dirt I haven't had trouble with, but miscellaneous streaks I have, which does require a cleaning fluid of some sort (I like water) and moderate amount of rubbing with soft cloth.
11-08-2009, 07:11 PM   #5
I've had the same problem myself. I'm not sure why I didn't think of the soap and water idea. The streaks look like oil of some sort and are really difficult to remove.
11-08-2009, 07:16 PM   #6
Andi Lo's Avatar
Lens pen makes cleaning Hoya filters easier I have some hoya filters myself and they're a pain to clean without the lenspen.
I assume that you got the pro-d stuff? the new HD / HMC (or something like that) is reputedly easier to clean. (although reading the post somwehre above me it seems that it's not?)
11-08-2009, 07:46 PM   #7
creampuff's Avatar
Hoya has had a crappy reputation when it comes to cleaning the surface of their filters. One of the reasons why some opt for other brands like B+W, Marumi or Kenko. However the new Hoya HD filters are dead easy to clean and uber tough. Have never had a problem at all either with the UV or Cir-Pol ones... well worth the money.
11-08-2009, 08:02 PM   #8
dadipentak's Avatar
I'm relieved to hear I'm not the only one with this problem.
11-08-2009, 08:08 PM   #9
monochrome's Avatar
Residual Oil Remover
Try Residual Oil Remover. Works for me anyway.
Available at B&H Photo in spray form and online camera stores as a fluid.
11-08-2009, 09:10 PM   #10
dave9t5's Avatar
QuoteOriginally posted by reeftool Quote
It's very easy to clean coated eyeglasses: under running water with dish-soap followed by a wipe with a Kleenex tissue.
11-08-2009, 09:49 PM   #11
jslifoaw's Avatar
All of my Hoyas (older HMCs) are a pain to clean, and B+W MRCs are the complete opposite for me. However, you also need to ensure you have a good microfibre cloth that is clean. I got one as a bonus gift for ordering a bunch of filters from hvstar on ebay and it works better than anything else I've owned up to this point.
I generally start wiping from the middle and work my way to the edges; in a worst case this may leave a very thing ring around the edge but the centre parts are clear.
11-09-2009, 09:17 AM   #12
reeftool's Avatar
QuoteOriginally posted by dave9t5 Quote
As I mentioned, I found distilled water best for all around lens cleaning. I'm a mechanic for a living and I have to clean my glasses a lot. I found the anti glare coating to be more of a hassle than a benefit. As for filters, those coatings are what make the filter do its job so we have to live with it.
filters, k-mount, pentax lens, slr lens
For Sale - Sold: Trade: My 77mm filters for your 72mm filters (CONUS) loveisageless Sold Items 0 10-02-2010 12:29 AM
Clean Orli Troubleshooting and Beginner Help 2 01-04-2010 02:58 AM
How do you clean your lenses / filters - LensPen? jaz Pentax SLR Lens Discussion 11 07-14-2009 05:02 PM
How to clean ND grad filters netuser Pentax Camera and Field Accessories 6 02-07-2009 02:13 PM
All times are GMT -7. The time now is 10:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
