Originally posted by Timbuctoo Ahh, that's great to hear, I have looked for pics of the lens to try and see the 'A' on the ring but I can't see it. So you can confirm that the lens meters in AV mode without the need for stop down metering? If so I might pick up one of those New/Old ones if I can find one.
If the lens has an "A" on the aperture ring it will definitely meter without you having to manually step down, as long as you keep it locked in the "A" position.
The only thing this lens does not do is AF and it also doesn't record the focal length in the EXIF, unless you manually add it when using the shake reduction.
