You have wonderful pictures. Pentax primes are in general small, lightweight, sturdy and great for traveling.
You often hear suggestions of Pentax limited trio with pancake in DA limited lens line as in Pentax DA 21mm f/3.2, DA 40mm f/2.8 and DA 70mm f/2.4. The DA limited tend to be smaller and lighter due to the pancake design and they focus faster than the FA limited lens equivalent but slower in speed. Speed can be subjective in the choosing but I tend to weigh in more importance on speed to make up the lacking of noise control on my K20D that is lacking beyond iso 3200 and higher. In hindsight, I wish to have Pentax DA 70mm f/2.4 instead of Pentax FA 77mm f/1.8 for the gain in AF speed along with the quick shift focus support that the DA limited lens provide where you can override the AF by turning the focus ring manually and enable AF button to engage (or cancel) AF to find ways to manual focus at critical moments that AF may fail us more than helping us make the shot. Marc can probably explain it better to you on quick shift focus as he shoot frequently with indoor concert events
The
limited pancake trio in 21/40/70mm is extremely small set and great lens lineup for traveling. I have a combination of DA (digital) limited along with FA limited (faster and full frame compatible).
For fun factor to add to the limited lens for lightweight, I will include the
Pentax DA 10-17mm f/3.5-4.5 fisheye which may not appeal to some due to the fisheye distortion but I really like to use the lens with my boys in museums, indoor events, fireworks and distortion is not bad 15 to 17mm and the 10mm is the fun factor lens with my family. PF/CA is very apparent with the fisheye lens though the fun factor.
Hope you join us to be a Pentaxian. In Pentax bodies, we pride in the SR (shake reduction) that are built into the bodies and work with all lens mounted, be it 3rd party, m42 lens, or manual focus lens. The SR will work beautifully. You are more likely to see long shutter 1/30 sec to 1/4 sec hand-holding shots without tripod on a ordinary lens mounted on the Pentax body. Whether SR is as good as VR or IS, that is a different subject worth debating, I pride in my Pentax system that I have SR working for a $5.00 used lens that I have in my bag -- we have a term called LBA with Lens Buying Addiction and it may have something to do the SR feature and backward compatibility in Pentax.
The Pentax DA 16-45mm f/4.0 is a wonderful lens for traveling, I settle my walk-around lens with
Sigma 17-70mm f/2.8-4.5. It is not as sleek with constant speed but it gains on close up with 1:2.3 and a more usable range for walk-around. I chose it over the Pentax DA 17-70mm f/4.0 as I find it cheaper to own as I bought it used for $300.00. And the SR works as advocated with all shots hand-held
1/3 sec, f/5.6, 53mm, iso 400, 0 Ev
1/5 sec, f/6.3, 17mm, iso 500, 0 Ev
1/40 sec, f/4.0, 40mm, iso 400, 0 Ev
1/2000 sec, f/7.1, 70mm, iso 400, 0 Ev
Hin
