Originally posted by Pål Jensen Which FA* lens?
What is MAF?
Anyway, if you mean that theres a piece of plastic below the focusing scale window, then the window is just glued in place with some sort of never drying soft glue. It should be easy to pry off; but it is also very easy to break...
Is a FA* 28-70, and yes the MAF is the focusing scale.
and yes, the piece is in there.
that's why I thought about the plate number is set, If I remove the screw as the remove??
tkx
Originally posted by pcarfan May be if you can a post a picture it would clear things up.
difficult to make, the piece is small, and you can only see if I rotate, the FA * down
tkx
