11-16-2009, 12:32 PM   #1
Teleconverter with DA* 50-135?
Like the title says, can I use a teleconverter with the DA* 50-135? Will I get a reduction in the aperture opening? I like that lens for the f2.8 as well as the weather sealing, but I think it's weakness is the short 135mm focal length. There is of course the *60-250 but it's twice the price and only F4.
11-16-2009, 12:53 PM   #2
Ash
Community Manager
Ash's Avatar
Never tried a TC on the 50-135, so couldn't help you there, but TCs do reduce the effective aperture by 1 stop (for 1.4x), 1.5 stops (for 1.7x) and 2 stops (for 2x).
You want something longer but still want f/2.8 - you'll have to go to one of the 70-200 f/2.8 offerings, or invest in Pentax's FA* 80-200.
11-16-2009, 01:29 PM   #3
Ok, so not too far away from the 60-250 then in terms of light with a TC. It's almost like having two lenses in one!
Someone please talk me out of this lens, too tempting!
11-16-2009, 01:52 PM   #4
Ash
Community Manager
Ash's Avatar
If you're referring to the 50-135 + TC, don't hold your breath. AF performance on SDM lenses have not been all that impressive with the current lineup of SDM-compatible TCs. The Tamron 1.4x TC is probably the closest to working with SDM lenses, but it works more reliably with screwdrive lenses like the Tamron 70-200.
11-16-2009, 01:58 PM   #5
I have this DA*50-135 and have tried it with:
- Tamron 1.4x TC (auto focus)
it works but needs a good light. If the light level is low or dim, you'll get frustrated using this combo. The focus will hunt and takes a while before it stops focusing or not at all. So it's a 50:50 situation. You get the extra reach for sure and not too bad IQ but I'd say just forget about the auto focus.
- Vivitar 2x MFTC (Macro, manual)
with this TC it will work since it's manual anyway. The good thing with this TC is even though you will lose 2 stops, the IQ is just amazing. My copy is very good. I couldn't even any loss in IQ using this TC and any lens. I never used the regular 2x TC but from what I read the IQ will drop significantly. With this Vivitar 2x MFTC, I haven't seen anything bad comes out of it.
This same TC turns my already sharp FA 43Ltd into an unbelievably sharp 86mm MACRO Limited
11-16-2009, 05:00 PM   #6
Canada_Rockies's Avatar
I have tried my 50-135 with both the A 1.4X-S and F 1.7X AF converters. The image quality is really quite good. So I have a manual focus 70-190 f/4 and an 85-230 f/4.8 lens with automatic focus touch up. I have only done quick tests at about 7 metres (the width of a room with bookshelves at the far end), but the lens looks to be quite useful with either. I have not dared to stack them to see what I would get. Yet.
11-17-2009, 03:32 PM   #7
QuoteOriginally posted by sebberry Quote
I think you will find the numbers tell a small part of the story.
The 50-135 is a blistering lens in it's own right, but put it on a TC and two things will happen. The IQ will be lowered and the autofocussing will be much slower and less reliable.
Hold out for the 60-250.
11-17-2009, 03:38 PM   #8
QuoteOriginally posted by Oggy Quote
Thanks for the info.
Up here it's $2100 lens with taxes. I'm just a hobbyist, not a pro
11-17-2009, 04:52 PM   #9
I have the Tamron 1.4 teleconverter and the 50-135mm. Did a test with them last week and see no degradation whatsoever. Autofocus does hunt just a little more in the shade or dimmer light but in daylight it is pretty much a non issue. I have seen reports on the same combo to the contrary. I am happy with the combination myself. I rented a 60-250 in October to use on a whale watching cruise in Seattle. After hauling the lens around for 4 days the second picture I took did not focus and after that it was very hard to zoom and the stiffness varied from turn to turn of the zoom collar. I took the lens off the camera and looked through it and could see an "O" Ring hanging down. Something failed inside of the lens. Probably a seal. After that I boought the Tamron MC 1.4 converter to achieve some of the same focal lenngth while carrying around a much lighter lens. It will do for now.
11-17-2009, 04:59 PM   #10
QuoteOriginally posted by GaryH Quote
Thanks for the feedback.
I suppose being a rental the 60-250 might have been treated a bit diferently but to hear about something like that on a lens of that price is a bit disappointing. I can see a two year warranty on the DA series, but IMO the DA* should come with a 5 year if not more.
11-18-2009, 10:52 AM   #11
I was very disappointed in the 60-250 failure. Was really considering that lens. Now I beleive the Sigma 100-300 f4 might suit my needs better. I like the idea of internal zooming like the 50-135 has. Ended up taking whale pictures with a 17-70. Not much in the way of close ups....
I can send you comparison pictures with and without the teleconverter if you would like. Just PM me your email.
11-19-2009, 07:34 AM   #12
dgaies's Avatar
Well, after reading this and coming across a relatively inexpensive used Tamron 1.4x, I decided to buy it and give it a try with my 50-135mm... and here I thought today might be the day I finally leave my credit card in my wallet (and not purchase any Pentax related products).
11-19-2009, 08:06 AM   #13
vizjerei's Avatar
I have a pentax-A 2x TC used on 50-135, the result is very good.
11-19-2009, 12:18 PM   #14
Thanks for the feedback everyone, and thanks Gary for the shots! You might want to post one or two here so people can see the results
11-19-2009, 01:28 PM   #15
philbaum's Avatar
I had, like others, read some post about TC's not working well with the 50-135. I just tried it myself. Glad i did.
I have the Tamron 1.4 with power zoom contacts, enabling SDM. Today in my area its very gray with constant rain, noon. I focused on some very fine branches on the side of a tree abt 35 feet away. The SDM locked but when i checked the image at 8X magnification on the LCD, it was not acceptable sharpness. When i manually focused, i got an acceptable sharpness at 8X LCD zoom (equiv to 100% crop, i believe) This was at 1/250 shutter, 2.8 aperture, and 800 ISO, handheld.
This is great news. I have no doubt in normal daytime lighting that this combo would focus on SDM. And even in less light, i could always use manual focus with this combo. And as someone else said, the 50-135 is far lighter than a 70-200 to carry around.
da*, k-mount, pentax lens, slr lens, teleconverter, teleconverter with da*
Chinon 135 & Chinar 135 , Good Bad or Ugly seacapt Pentax SLR Lens Discussion 1 02-26-2010 09:03 PM
50-135 DA f2.8 with teleconverter? lufc2001 Pentax SLR Lens Discussion 5 11-03-2008 10:07 PM
For Sale - Sold: FS: Pentax 12-24, 50-135, sigma 70-300, teleconverter etc pastorbbc Sold Items 15 02-28-2008 05:44 PM
Help on a teleconverter for Sigma 135-400mm rdrum76 Pentax SLR Lens Discussion 4 06-25-2007 12:51 AM
All times are GMT -7. The time now is 10:30 PM. | See also: NikonForums.com, part of our network of photo forums!
