The cap is attached to the lens with different degrees of tightness (you control how much to twist the cap on). At the greatest tightness. it's not possible for me to remove the cap with one hand. But it is doable if I don't tighten the cap too hard. A nice thing is that it's not easy for the cap to detach itself from the lens, even with a moderate degree of tightness.
However, there is a minor problem in attaching the cap to the lens: the small bump on the cap has to be aligned with the red dot on the lens. In the photo, you can see the bump on the free standing cap at 6 o'clock position and on the one attached to the lenses at 11 o'clock position. It's not as bad as some Tamron or Sigma caps because it's easy to feel the bump.
The tightness of the Op/Tech double lens cap is particularly suitable for quick lens changing because it is attached tight to the lens. My DIY double lens caps are pretty loose so I have to be careful not to drop the cap (or the lens
) in the process. There is no danger like that with the Op/Tech lens caps.
I'll keep these two caps for my Ltd lenses, and will probably buy a few more, not one for each lens, but one for each lens I carry for a photo session for fast lens swapping.
