06-08-2007, 12:16 PM   #16
I have 3 teleconverters, one sigma to go with my autofocus 70-200 F2.8, one pentax 1.7x autoficus adaptor, and one 2x Pentax A TC
Does your Pentax-A 2x TC + some KA-bayonet lens + K10D combo meter properly without any +/- EV adjustments?
Your other TC:s are different story because they are KAF-compatible.....
06-08-2007, 02:31 PM   #17
Lowell Goudge's Avatar
QuoteOriginally posted by Harald Quote
My lens selection is limited.
I have either new modern AF zooms or K mount primes. No KA mount lenses
Sorry
06-08-2007, 04:50 PM   #18
Mine sure do- I've tested the setup with my A* 200mm and the A-2xS converter. TTL metering even works with manual lenses, but you'll have to stop down to meter first.
So, in conclusion, only the F teleconverter shows the aperture change in the viewfinder, but the A teleconverters are still able to meter correctly through TTL and compensate for the loss of the two stops.
Speaking in general, the K10D has substantial metering issues with wide-angle manual-aperture lenses. This should't be the case with auto-aperture lenses, though...
06-09-2007, 12:16 AM   #19
QuoteOriginally posted by Mo Quote
I was wondering... can this be due to a too weak shutter mechanism in the body? if the shutter actuator is too weak to handle the load of the converter and the lens together....
Could this also be behind the some reported problems with K and M-lenses too; older, little stiff mechanism could be similar higher load to the too weak actuator than newer A-series lens + TC......
I sold this spring an Tamron 80-210/2.8 adaptall-2 lens I had not used much with the K10. Buyer complained that aperture didnt close properly but closes less than it should do. We tried other adaptall KA adapters and found one which worked reasonably well. If the actuator is too weak, it could explain this episode too......
06-09-2007, 12:24 AM   #20
The lever in the converter doesn't add much load to the camera mechanism, so that shouldn't be a problem. There might be something wrong with the camera, but what could it be?
06-09-2007, 01:09 AM   #21
Actually all additional mechanisms adds the load, it is evident. I do not have proper equipmets to measure this other than my finger, but even it can give me feeling of stiffer movement of the lever.
If the actuator is too weak, capable only handle the lens aperture mechanism only just, this could happen.
I do not have problems with any single lens, without the TC.
Could this be one of those places where the very reasonable price (->desperate need to keep the manufacturing expences low) shows its concequences. (engineers chose one too cheap part )
2x, aperture, converter, k-mount, pentax lens, pentax-a, slr lens, sp, tamron
TAMRON TC converter pics jgredline Pentax SLR Lens Discussion 579 07-21-2012 09:00 AM
For Sale - Sold: Tamron 1,4x Tele-Converter for Pentax mmzymxf Sold Items 2 04-26-2009 04:09 PM
tamron af 1.4 converter jon pafford Pentax Camera and Field Accessories 0 11-17-2007 08:36 PM
Tamron SP 2x converter Shelob1 Pentax SLR Lens Discussion 10 09-26-2007 12:13 PM
All times are GMT -7. The time now is 07:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
